OEM Rear Sway Bar
OEM Rear Sway Bar
What years OEM sway bar from F250 will work for my Excursion?
If anyone has one from F250 or Excursion they've swapped for aftermarket I'd gladly free up some garage space for you. Only hit I got in the WTB marketplace was $328 for F350. I could go Hellwig if I wanted to pay that much. Not having any luck in the local salvage yards either.
While that may be true I've also read here where the upgrade was minimal. If I were doing heavy towing on a regular basis there'd be no question as to what I'd get. This is mainly a family hauler. I could go with an f350 which is beefier than what I've found for the F250. F350 was 30mm & F250 18.5mm. That's what I've found thus far.
I paid about $99 for my OEM Ford F350 sway bar. It is 30mm and comes with the bushings so you don't need to order those. I don't have the part number in front of me, but if the parts guys looks up the sway bar off a 2004 F350 SRW they will find the 30mm one.
I installed mine yesterday thinking it wouldn't be much of a difference over the stock bar, I was wrong. It made a very noticable difference and I am glad I did it. Stock is about 26mm if I remember right.
I'm sure the Hellwig would be great too, but this was cheaper for me. The Hellwig is a 31-32mm bar and I have no idea how it compares to the 30mm OEM. If it uses the same mounting points and is the same type of steel as OEM it will be slightly stiffer.
You'd need #7 in the picture if you don't have a stock bar.
2005 Ford Excursion Parts - Tousley Ford Parts Depot
Do all the axles come with the mount for that bracket?
This is what I'm talking about. His truck is 2011 SD but I'm more interested in how the bar mounts. Of course my shock axle mounts are different but seems it would work with the F350 bar & mounting brackets.
https://www.ford-trucks.com/forums/1...-pictures.html
There are brackets on there for the swaybar and they are not the same as the shock mounts. Here is a pic:
<iframe title ="Preview" scrolling="no" marginheight="0" marginwidth="0" frameborder="0" style="width:320px;height:240px;padding:0;backgrou nd-color:#fcfcfc;" src="https://skydrive.live.com/embedphoto.aspx/.Public/WP^_000032.jpg?cid=8197a8c48d411b70&sc=documents"> </iframe>
