O2 sensors on 1996 Explorer 4.0 - Ford Truck Enthusiasts Forums
Old 06-05-2011, 09:06 AM
hacker35 hacker35 is offline
hacker35 is starting off with a positive reputation.
The check engine light is lit on 1996 Eddie Bauer. It has the 4.0 V6. The ODC said it is the #1 sensor. Does anyone know the location of this sensor?
Old 06-05-2011, 10:17 AM
caseys's Avatar
caseys caseys is offline
caseys has a good reputation on FTE.caseys has a good reputation on FTE.
Quote:
Depends on what "bank" for your #1 sensor... bank 1 sensor 1 is forward of the cat on the passenger side, bank 2 sensor 1 is forward of the cat on the driver side.
Old 06-05-2011, 10:36 AM
02 sensor
Thanks. I believe it said bank 1. Once the sensor is changed, does anything have to be done to reset the check engine light or will it go out by itself?
Old 06-05-2011, 11:15 AM
shorod's Avatar
shorod shorod is online now
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
That will depend on why the code was set. Diagnostic codes don't ofter specify which part is bad, but rather what sensor is reporting an issue. Depending on the particular diagnostic code (there are SEVERAL relating to oxygen sensors), the issue could be with the wiring, due to a misfire/vacuum leak, improper fuel, etc. If you just replace the sensor and the problem is a broken wire to the sensor, no, the check engine light will not go out.
Do you happen to have the exact code, probably in the form of P0123?
-Rod
Old 06-05-2011, 11:24 AM
O2 sensor
No, I don't believe the ODC gave that. Thanks for the help.
Old 06-05-2011, 01:19 PM
caseys's Avatar
You will need to get a o2 sensor socket... it has a side cutout so you do not break the wire on the new sensor.
Old 06-06-2011, 02:51 AM
aquanaut20's Avatar
aquanaut20 aquanaut20 is offline
aquanaut20 is starting off with a positive reputation.
Be aware that without the proper diagnostics, changing parts may not fix the problem.
It will however lighten your wallet.. Philip
po 500 code chris1996 New Member Introductions 3 10-11-2016 03:37 PM
1996 4.0L coolant leak front left corner? steve(ill) Explorer, Sport Trac, Mountaineer & Aviator 6 04-29-2015 10:04 PM
P0500 Speed Sensor A Malfunction tlcarrig Aerostar 9 07-28-2013 09:18 PM
P0401 / P0402 deejdeej Ranger & B-Series 4 06-10-2010 10:51 PM
TEMPERATURE GAUGE SENSOR LOCATION claycomotrucks1991 Explorer, Sport Trac, Mountaineer & Aviator 3 05-31-2010 09:36 PM
Tags
02, 1, 1996, 40, 96, diagram, exploder, explorer, ford, location, locations, o2, oxygen, sensor, sensors, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
