Rims interchangeable between? - Ford Truck Enthusiasts Forums
Old 06-04-2011, 06:18 PM
Arbitris Arbitris is offline
Arbitris is starting off with a positive reputation.
Sorry for an uneducated question, but rims are not my strong point.
Here's what I know:
Frame is roughly a 1978 full size frame
(came with a title for a 78 Grand Marquis but I don't know how to verify this from the frame)
5 lug pattern, as it's a car frame
I tried to bolt on 5 lug car/ranger wheels
The lugs are too close together
- The guy that brought them by told me I had a f150 frame, however the frame has an axle hump in the rear and coil springs all around, I don't think it's a truck frame.
My question:
Is there a specific bolt pattern this would most likely be? If so what cars/trucks should I be able to get rims from? (at the self serve junk yard)
Can anybody point me at how to identify what frame I'm playing with?
Thanks in advance for any help!
Old 06-04-2011, 10:47 PM
PatsPOS PatsPOS is offline
PatsPOS is starting off with a positive reputation.
From '73 to '78, Ford fullsize cars used a bit of an oddball lug pattern...5 x 5". Hence the reason Ranger wheels wouldn't fit, and neither will truck wheels.
Your choices for finding factory wheels at the local yard are limited. Aside from finding a fullsize Ford car, I THINK the Chevy Astro had a 5 X 5" pattern...but that's just heresay. Oh, yeah...the '72-'79 midsize Ford police cars used that pattern too, if you happen to run across one...
Pat
Old 06-05-2011, 01:20 PM
Pat
Thanks Pat!
Old 06-19-2011, 03:53 AM
68Shortbox5.4's Avatar
68Shortbox5.4 68Shortbox5.4 is offline
68Shortbox5.4 is starting off with a positive reputation.
Before you run off and buy wheels with the 5x5 pattern, I believe Lincolns were the only one to use the 5x5 pattern, Ford and Merc used 5x4.5. If his wheels came off a Ranger and your lugs were to close then 5x5 would be bigger. Measure from the outside of one stud to the middle of the adjacent stud to get your pattern.
Old 06-19-2011, 07:24 PM
Quote:
My understanding has always been to measuer from center of stud to center of opposite stud (or close to opposite obviously with an odd number of lugs)
When I actually go pick some up I will probably take a piece of cardboard, smack it down over the studs to get the bolt pattern and bring it with me to hold up over the donor car studs and make sure they are the same size. I don't see new rims going on this.
Old 06-19-2011, 07:30 PM
I wonder how many of these cars are hub centric.
Old 06-19-2011, 07:32 PM
We are both correct, center to center is 6 and 8 my way is for 5
Old 06-19-2011, 08:00 PM
That's right, I forgot that the number is a measure of the radius, and in the case of the 5 lug pattern there isn't a bolt in the correct place to measure correctly for that number.
1980 Ranger bolt pattern conversion Xwarrior86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 05-06-2015 06:46 AM
Convert corvette rear suspension lug pattern The Outlaw 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 02-04-2014 09:01 AM
question about aftermarket rims xtamer 1997-2006 Expedition & Navigator 2 12-02-2013 12:50 PM
non ford truck- re 5 lug 8" rims hertfordnc 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 09-02-2011 02:22 PM
1946 1 ton rims? jdhudall Brakes, Steering, Suspension, Tires, & Wheels 4 05-24-2011 12:15 AM
Tags
1997, aerostar, astro, car, expedition, f150, ford, interchangable, interchangeable, ranger, rims, sizes, stud, truck, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
