cross flow fuel issue
Couple months ago my 93 half ton 302 started pumping into the rear tank. The factory issued recall had me tow my truck to Jim keim Ford only to tell me my truck was not covered under the recall. They could not even tell me why it wasn't covered when the recall showed all 80-96 trucks and vans with duel tanks that had the issue were covered. Can anyone tell me the part that has failed and possibly why it is not covered?
The part you need is a Fuel Delivery Module/Assembly (FDM).
It either has a bad high pressure check valve in inside it or a bad shuttle valve.
The bad FDM is in the tank that is filling or in this case the rear tank.
Someone posted on here that the recall was only good for 12 years.
The FDM:
The FDM:
The recall has expired. might as well get a new tank, when you get the new pump, get the one thats the delivery module, you need the plastic that contains the check valve. You will have to use the fuel guage assy off your old pump, unless it don't work, then if that's the case you'll have to buy that too. Might want to check your fuel pressure, the origional recall was because the fuel pressure regulator was made from carbon steel, and wore out putting full pressure against the check valve causing it to fail. I had to replace mine, when I did the pump.
I bought the tank from rock auto for about $100, the fuel pump came from advanced for about $150, it's an airtech, with a lifetime warrenty
2002exPSD
11-01-2013 07:53 AM
lar316
1999 to 2016 Super Duty
05-14-2013 11:02 PM
drexyl
01-27-2010 07:01 AM
tmcalavy
09-05-2001 11:14 AM
