6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Upfitter High Idle Mod on 6.4?
Old 06-03-2011, 11:10 PM
Lonzom10's Avatar
Lonzom10
Lonzom10 is offline
So my 08 F250 came with the 4 upfitter switches already installed. I've been reading about what to use these for and noticed that a lot of owners are using switch #4 for the High Idle mod. I'm not running any type of PTO nor do I plan to so my main questions at this point are... Are any of you applying this mod to your 6.4L engine? Why or why not? What are the benefits?
In addition to this, what are you using your other AUX switches for? Just wondering. Thanks in advance!
Old 06-03-2011, 11:15 PM
Brandon D's Avatar
Brandon D
Brandon D is offline
Lead Foot User
https://www.ford-trucks.com/forums/6...high-idle.html
Here is a link to a thread that goes into detail about how to do it and why to do it. I did it to mine and always use it in cold weather and when the truck is idling for extended periods. Good Luck
Old 06-03-2011, 11:56 PM
Lonzom10's Avatar
Lonzom10
Lonzom10 is offline
Thanks Brandon... Very helpful!
What do you use your other switches for?
Old 06-04-2011, 06:16 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
I use #4 with the high idle mod. Especially here in Texas where we keep the air conditioner running and idling a lot. Winter time, I use it to actually warm things up a bit before I take off. Start the truck, let it low idle for a bit, then go to High idle, cooling and heating more quickly its a plu. It does suck fuel! I notice that its uses a lot more fuel in High Idle, but I think the pros outweigh the cons.
Old 06-04-2011, 08:30 AM
Brandon D's Avatar
Brandon D
Lead Foot User
No problem and I currently only use #4 for high idle. I'm going to add a solenoid valve to my slip tank fuel line and put it on one of the other upfitters so I can transfer fuel without leaving the cab but I haven't gotten around to it yet. The possibilities are endless so now you can start adding toys to the new truck!
Old 06-05-2011, 07:43 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
I used the directions found here on this forum to do my high idle mod too. Mine is also connected to #4. I use it to warm up the truck in the winter and will use it to keep the rpm's up in this summer while out of the truck and my pups still inside with the a/c on. It takes all of 10 minutes to do. The largest portion of that time is finding the wires.
Old 06-05-2011, 08:38 AM
wp6529's Avatar
wp6529
wp6529 is offline
Aux1 - Not in use yet.
Aux2 - SEIC mode, with an RPM setting potentiometer in place of the power port next to the pedal adjust switch.
Aux3 - BCP mode (useful when using a winch, idles up the engine when the winch is drawing a lot of power).
Aux4 - 12V Aux enable (controls a big contactor/relay to enable a 200A+ power feed to a 2KW inverter and a connection for a receiver mount winch).
Old 06-05-2011, 12:13 PM
farmb0y's Avatar
farmb0y
farmb0y is offline
Thanks for the info and links, I had it no my old 7.3L and would really like the high idle on this new one.
Old 06-06-2011, 07:42 PM
Lonzom10's Avatar
Lonzom10
Lonzom10 is offline
@ Brandon - I'm trying to get this to work on my 08 6.4 but so far no luck. My 4 Aux wires are as follows:
- Off White
- White with Orange Stripe
- Brown with White Stripe
- Gray with orange stripe
So far I have tried hooking the Green & Yellow wire to the Off White with no success. I then tried attaching it to the Brown with White Stripe and still no luck. Any suggestions on what I could be doing wrong?
Thanks in Advance! Sorry for the trouble.
Old 06-06-2011, 08:06 PM
golfmedik's Avatar
golfmedik
Remember to set the parking brake.
Old 06-06-2011, 08:35 PM
Lonzom10's Avatar
Lonzom10
Lonzom10 is offline
When all else fells get a flash light and make sure you are using the right wires... Went back out after my last post with the flashlight to find I was actually using the wrong wires. The wires for my AUX switches were tucked a little further up in the dash. Found the brown wire, connected it to the Yellow & Green Wire, applied EBrake, Flipped the switch and presto... 1200RPMS! Thanks for the responses guys... sorry for the trouble! It only took an hour but I finally got it... walking away from PC in shame...
Old 06-06-2011, 10:42 PM
Brandon D's Avatar
Brandon D
Lead Foot User
Sorry I wasn't around earlier but would have suggested either the park brake or to make sure you had the right wires. I almost made the same mistake and found the right wires taped up a little higher. Glad you got it figured out and don't be ashamed, you'd be surprised at how many guys are unable to do this simple job and take it to the dealer. How foolish would you feel if you paid an hour of shop labor for that easy of a job? Cheers
F250SDPowerStroke
1999 to 2016 Super Duty
106
01-26-2019 10:43 PM
Jhndere
2017+ Super Duty
12-22-2016 11:42 AM
90pioneer
6.7L Power Stroke Diesel
11-02-2015 11:48 AM
gone campin
08-31-2010 04:03 AM
sweeted
04-19-2010 02:43 PM
Quick Reply: Upfitter High Idle Mod on 6.4?
