Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
  #1 (permalink)
Old 06-03-2011, 09:50 PM
Thermo2008 Thermo2008 is offline
Garage is empty, add now
Thermo2008 is starting off with a positive reputation.
Reduced engine power 6.4 psd
Was test driving a truck to buy today and was getting on freeway going 75 about a mile down the road reduced engine power and wrench light came on not a good way to start a test drive any ideas truck ran well until that point. 37000 miles still under eng warranty just a little Leary they cannot check out until mon morning
  #2 (permalink)
Old 06-03-2011, 09:54 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
2011 Ford F-350
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.4L Powerstroke Diesel forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #3 (permalink)
Old 06-04-2011, 06:12 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Could be something as simple as a sensor. Bottom line is a fault was detected and it entered a safe mode to prevent further damage.
__________________
http://www.ford-trucks.com/forums/pi...ctureid=114550
Scott-2008 F250 PSD Crew Cab 4x4, 12K GVWR,
Cooper Discovery STT LT275/70R18's
Banks Ram Air & 6-Gun, Ravelco Alarm System, Frontier Extreme FT. Bumper
2013 40' 4-slider stoneridge 5th wheel coming in at 15,400
http://www.ford-trucks.com/guidelines.html
  #4 (permalink)
Old 06-04-2011, 09:35 AM
Crazy001's Avatar
Crazy001 Crazy001 is offline
2000 Ford Excursion
Crazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputationCrazy001 has a superb reputation
TomB985
Hi Thermo, welcome to FTE!
Unfortunately things sometimes go wrong with engines as complex as these are, but for the most part they do pretty well. With as much engine warranty as there is left I wouldn't hesitate to buy it once the problem is corrected. Scott is probably correct in that it's likely a sensor problem.
Take a look around and also make sure to visit the TECH FOLDER found at the top of the 6.4L forum. Lots of great info to be found there that would be beneficial for you to know before you make the purchase.
Let us know if you get the truck, and be sure to post pics!
__________________
Tom,
2013 F150 XLT 4x4 EcoBoost
  #5 (permalink)
Old 06-04-2011, 09:54 AM
Probabaly something simple. Really like the truck well just don't want it to be a cronic problem if I buy truck! Talked to sales person today and won't have a diesel tech until Monday morning to diagnose problem. I will send updates when I find out more. 2008 f250 Xlt 4x2 crew long bed.
  #6 (permalink)
Old 06-06-2011, 09:15 PM
Talked to service dept today and they said 1 of the engine thermostats failed not sure which one I know there are two. And from what I have read they take 3 hrs book time. Could not pick up truck today.will tomorrow arranged to drive truck for a couple days before buying so I could check over and make sure no other problems.
  #7 (permalink)
Old 06-06-2011, 09:25 PM
Crazy001's Avatar
2000 Ford Excursion
TomB985
Glad to hear they found the problem! Did you notice what your temperature gauge read when it went to limp-home mode?
__________________
Tom,
  #8 (permalink)
Old 06-06-2011, 09:34 PM
Well I looked at it a couple times and showed normal. With the 2 t stats I wonder if 1 is for main coolant and one for egr system?
  #9 (permalink)
Old 06-06-2011, 09:51 PM
Crazy001's Avatar
2000 Ford Excursion
TomB985
Nope, there is only one cooling system on these engines. You're thinking of the 6.7L! .
There are two thermostats that control flow of coolant to the radiator, if one is stuck open I believe you'd be overcooling.
__________________
Tom,
  #10 (permalink)
Old 06-07-2011, 05:13 AM
senix's Avatar
I suppose hyper extended was the issues. My temp guage will move just to the right of center at 220F.
__________________
  #11 (permalink)
Old 06-07-2011, 09:39 AM
wp6529 wp6529 is offline
wp6529 is gaining momentum as a positive member of FTE.
Quote:
Actually there are two fully independent cooling systems on the 6.4. There is a separate system with a separate pump and radiator for the fuel cooler and variable turbo actuator.
  #12 (permalink)
Old 06-07-2011, 11:52 AM
Crazy001's Avatar
2000 Ford Excursion
TomB985
Quote:
Correct, but I do not believe there is a thermostat for that system.
__________________
Tom,
  #13 (permalink)
Old 06-08-2011, 09:50 PM
Well bought the truck
I bought the truck today. They let me drive it for a couple days. Great dealer ship seem very knowledgeable on diesels. Buckeye ford London Ohio. Rural dealer stocks a lot of diesels. Found no other problems hope it stays that way.hope to be a long time ford enthusiast!
  #14 (permalink)
Old 06-11-2011, 07:39 PM
powerskull's Avatar
powerskull powerskull is offline
powerskull is starting off with a positive reputation.
Congrats. I love mine and it pulls like nothing else.
  #15 (permalink)
Old 06-11-2011, 07:50 PM
I am pulling my 30 ft Airstream wed and will put it through its paces.I pulled it before w/ my dad's 6.0 liter and that truck pulled it great.excited to see power.have driven it no load andhave never seen anything about dpf cleaning approx. 400 miles is this normal.I know it has latest software update.
Tags
2008, 64, engin, engine, f250, f350, f450, ford, icon, light, low, message, power, powerstroke, reduced, warning, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
