Dead OBDII port??
Dead OBDII port??
Does anyone know why the OBDII port might stop working? My CEL comes on every once in a while, and I know what the problem is, but I always like to check and clear the code to make sure its not something new. Today when I plugged in my code reader nothing happened. Normally the reader pulls power from the port but it just stayed off.
Is the OBDII port fused? Or is there something else I should check?
On your '02 it should be fuse 12.
Also here is a link to the owners manual.
http://www.motorcraftservice.com/pub.../02f23og5e.pdf
Thanks I will check number 12! If anyone else can find me a pdf of the right manual (diesel supplement would be appreciated too) then I will be very thankful.
I has happened here before and it took us all a while to figure it out. Eventually someone asked the question and the OP had a good laugh because his key was in the off position.
Go to Official Ford, Lincoln & Mercury Owner Site | Personalized Owner Information | FLMowner.com then register. Input your VIN number and you will ave full access to all the owners manuals and supplements. It is a pretty handy site that if you want can track maintenance for you too.
