Changing A/C compressor clutch in 2001 F-150 - Ford Truck Enthusiasts Forums
Old 06-03-2011, 06:53 PM
WINGNUT- WINGNUT- is offline
WINGNUT- is starting off with a positive reputation.
The A/C in my truck stopped working last year, and this year I intend to fix it. I believe the problem is with the compressor clutch because it was making noise as it would engage or disengage. It was making this noise for a good year or so, and then one day the noise stopped and I have no A/C. So I am only `assuming` its the clutch. A new one at NAPA is $180. Has anyone tried changing these?
Old 06-05-2011, 05:37 PM
dustybumpers's Avatar
dustybumpers dustybumpers is offline
Posting Legend
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
Before you buy anything, yoi may want to put a set of guages on it. It sounds like you are low on freon.
Old 08-29-2011, 05:54 PM
I just bought a refrigerant tester for the A/C system. I need to attach the connector to the A/C service port. The connector on the unit will not fit on the port I located which is near the battery. Is this the correct port, or is the connector on the tester simply the wrong size for my application?
Old 08-29-2011, 06:02 PM
I just checked the directions again, I need to locate the 'low-side' A/C port. Is this the port located near the battery or did Ford put the low side port in an impossible to find area to punish DIYers? I would assume the port size is supposed to be an industry standard so it should fit.....am I right?
Old 08-29-2011, 09:14 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
The Low Side port is located in the line between the evaporator and compressor on the "suction" side of the system. Usually on the accumulator.
Just keep in mind that the gauge you are using will only tell you if there is "some" refrigerant in the system. It can't tell you how much. If it has markings like Low-Good- High, take it back or throw it away. If it has markings in psi, then it can be somewhat useful.
air conditining compressor pulley/clutch bearing? granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-25-2013 08:56 AM
Belt squeal at a/c compressor dieselfumes12 1999 to 2016 Super Duty 3 12-18-2012 08:52 PM
A/C Compressor Belt Squeal dpslusser 1999 - 2003 7.3L Power Stroke Diesel 13 09-05-2012 11:42 PM
A/C Compressor Clutch texaskid22 1987 - 1996 F150 & Larger F-Series Trucks 1 02-21-2011 11:36 AM
03 Navigator AC clutch making noise fixit5561 Cooling, Heating, Ventilation & A/C 6 08-07-2010 09:14 AM
Tags
2001, 2003, ac, change, chevy, clutch, compressor, diagram, expedition, f150, ford, replace, replacing, silverado, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
