You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Title says it. I have a 1976 Highboy play/boat puller.. I'm looking for a solid fe 360/390 longblock that is Reliable. The 360 that is in it is pretty rough and I don't feel like dumping tons of money into it to get everything fixed. With that said, who has a reasonably priced reliable 360/390 They are wanting to sell?
I have one that has under 10k on a rebuild. 360, torque grind cam, cam timing advanced, cast iron S code 4BBL intake and 600cfm Holley 4160 vacuum secondary 4BBL. Mirror "105" block, very strong engine, pulls loads with ease, and is being pulled for a diesel swap. Clutch has same miles as the engine, comes with DSII electronic ignition.
I also have a spare 390 crank and rods, and can provide engine with flexplate or flywheel.
$1200 takes it all, picked up in Rexburg, ID or I can crate and ship at cost.
__________________
Jared
Real trucks have the key on the left FTE Guidelines
Sure is, it currently has a center sump pan but I have a rear sump pickup and pan i can put on it for you to make it even more ready. I can shoot a video of it running tomorrow if you'd like.
__________________
Jared
I got a video, but it needs new plug wires.
[youtube]9zOWgRQHgFg[/youtube]
You can hear a bit of a misfire at higher rpms, so I pulled the plugs and checked it all out, compression is fine at 155-160 across the board.
Here's a pic:
Here it is on the stand when I first put it together:
__________________
Jared
I've got a bone stock 352 here in Middle TN, smokes a little on start-up but came from a running/driving 1966. Carb needs to be fine tuned, it was a rebuilt that was just put on. $150 takes it home.
__________________
1968 F100 SWB 360, 3-speed With 110,xxx original miles
1969 F100 SWB 76,xxx Original Miles, In Process of Frame off Restomod
Love Them Ole Bumpsides!!
