AC clutch not engaging need help! - Ford Truck Enthusiasts Forums
Old 06-02-2011, 09:15 PM
tfs2403's Avatar
tfs2403 tfs2403 is offline
tfs2403 is starting off with a positive reputation.
Hi all,
I need help trying toget my kids AC up and going for the summer.
92 F150 w/5.8.
With engine started, and the AC on "max or normal" setting the compressor clutch does not engage, not even an attempt.
I threw a meter on the wires/plug going to compressor and nothing, no 12 volts, no measured charge on the meter at all - (engine running A/c on).
Now, if you haven't already figured it out I know nothing about A/C systems.
I have checked fuzes, ect. and everything seems to be in order there. Where should I begin to search for the problem.
Thanks for any and all help.
Robb
Old 06-02-2011, 09:21 PM
dcarnut1's Avatar
dcarnut1 dcarnut1 is offline
dcarnut1 is starting off with a positive reputation.
If the system is low on refrigerant the clutch will not engage. You can bypass this by jumping the low pressure cut off switch. it is the switch mounted on the dryer (black cylinder on pass firewall). Disconnect the wireing harness and jump with a paper clip, clutch should engage.
Old 06-02-2011, 09:40 PM
tfs2403's Avatar
will give it a try, Thanks
Old 06-02-2011, 09:45 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
If it does kick in and run, don't run it long with the jumper. That switch is to protect the compressor when the freon is low..
Old 06-02-2011, 10:03 PM
blkF250HD's Avatar
blkF250HD blkF250HD is offline
blkF250HD is gaining momentum as a positive member of FTE.blkF250HD is gaining momentum as a positive member of FTE.
Have the system recovered and deep vac'd to check for a leak. The clutch isn't engaging for a reason, there isn't enough refrigerant in the system. If the low side pressure gets too low for an extended period of time the evaporator will freeze up, and the high side pressure will be out of control, possibly damaging the condenser or compressor. Don't try to rig it or anything, have it fixed correctly.
FWIW: being a '92, your truck originally came with R-12. Retrofit kits are available to convert to R-134a, however the oil and seals will need to be changed as they are not compatible.
Old 06-07-2011, 10:34 PM
tfs2403's Avatar
update
I did jump the plug and the clutch did engage. So what now? Do I need to take this in and have it all checked out by a pro or can I get this thing working with a little elbow grease of my own?
Thanks
Robb
Old 06-07-2011, 10:39 PM
octaneforce's Avatar
octaneforce octaneforce is offline
octaneforce is starting off with a positive reputation.
my truck is a 92 and it called for r12, however i pumped it up with r134a and i havent had a problem. i got the little retrofit things that screw onto the low and high pressure ports. you can get the retrofit kit and pump it up with r134a at your own risk. like i said, mine works great, but others have not had the same luck. they make r12 substitutes i think. the last one ive heard of was freeze12. your most likely low on refrigerant.
Old 06-07-2011, 11:35 PM
dcarnut1's Avatar
Does the system have any pressure at all? With the compressor off the pressure will equalize across the system, should be around 150 psi.
If you have little or no pressure you have a leak in the system. just fixed one today that had a pinhole in the condensor discharge line.
Has the system been retrofitted? R12 system has small service ports with threads on the outside, R134 system has 2 different sized ports with threads on the inside. R12 systems used mineral oil for lubrication, R134 sytems use Pag oil. Mineral oil is not compatible with R134.
To work on the AC sytem you will need a set of ac gagues, Vacuum pump, refrigerent, seals, dye, etc. It is probably 6's to buy the tools or to pay a shop. If you plan to work on many vehicles, buy the tools. If this is the only vehicle you plan to work on, pay a pro.
Old 06-08-2011, 10:47 AM
hav24wheel's Avatar
hav24wheel hav24wheel is offline
hav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputationhav24wheel has a superb reputation
Retro fit kit, and a couple cans of R134, and a cheapy guage should do it. I've converted a couple vehicles and charged up with a single guage kit many times have had good luck.
Old 09-15-2011, 06:41 PM
blitzz66 blitzz66 is offline
blitzz66 is starting off with a positive reputation.
fuse blew now
did as suggested and the fuse blew clip melted in half so anyone know which fuse it might be because im not getting any air now ive checked all the fuses that have anything to do with ac and they are all good its a 2000 f350 7.3l
Quote:
Old 09-15-2011, 07:13 PM
well found it
well found it bypassing that low pressure switch and clutch still not kickn in any other suggestions
Old 09-15-2011, 07:23 PM
Bankrupter Bankrupter is offline
Bankrupter is gaining momentum as a positive member of FTE.
Quote:
Do you have power to the compressor ? I have seen a few that the wire is broken inside the compressor itself.
Old 09-15-2011, 07:37 PM
tfs2403's Avatar
update
Well I broke down and took it in to a shop. They found the compressor was bad, and there was a leak too. Due to other issues with the truck and the shop wanting over $500.00 to fix just the A/C we opted not to have it fixed. We are settling on 2/55 A/C (2 windows down, 55 mph)
Use the truck for a year or so and try to move up to something a little better shape.
THanks for the help guys I appreciate it!
Robb
Old 06-04-2016, 02:26 PM
Kimberlink Kimberlink is offline
Kimberlink is starting off with a positive reputation.
My 2001 f350 ac compressor clutch will not engage. I have voltage at compressor and it will engage if hooked to battery. Replaced connector for clutch. I have 35 lbs on low side when compressor jumped. Any suggestions I have also jumped high and low side switches. Need suggestions please
2007 Expedition A/C Clutch not engaging Netroamer 2007 - 2014 Expedition & Navigator 0 06-28-2016 10:44 PM
A/C compressor won't start CNGBuff Cooling, Heating, Ventilation & A/C 14 08-31-2015 08:06 AM
Please help 01 7.3 a/c joshua6430 1999 - 2003 7.3L Power Stroke Diesel 24 07-19-2015 12:05 PM
07 Expedition EL A/C Blowing Warm Air martyshel 2007 - 2014 Expedition & Navigator 2 05-07-2015 11:44 PM
Need A/C help with a '99 Superduty truckmonger1 Cooling, Heating, Ventilation & A/C 2 05-25-2010 09:44 PM
Tags
2000, 2003, 2004, ac, air, bypass, clutch, conditioner, cutoff, engaging, expedition, explorer, ford, low, pressure, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
