New user to the Sixties Ford Truck
Hi Everyone,
I am new to the Ford Truck Enthusiasts forum. I just purchased a 1962 Ford F100 Unibody. I am very excited about purchasing my first classic vehicle. I am like others here on the site. I would like to know more about my warranty plate information. My Vin# is F10JD301346. Here is the rest of my plate:
WB - 114
Color - T
Model - F10J
Trans - A
Axle - 11
Max. G.V.W. lbs - 05000
Cert - 114
H.P. R.P.M. - 3600
D.S.0. - 61
Thank you in advanced for any of your help on deciphering this information.
jasch
WB - 114
Color - T
Model - F10J
Trans - A
Axle - 11
Cert - 114
H.P. R.P.M. - 3600
D.S.0. - 61
jasch
No one really comes here but i drop in sometimes..
F10= F100
J= 223 inline 6
D= Dallas Texas assembly
301346= Consecutive unit number Born in June of 1962
WB - 114= Distance of wheels center to center a short bed
Color - T = Sandshell Beige
Model - F10J Mis on the last digit F100=5000GVW F101 4000GVW F102 5000GVW
Trans - A = 3 speed standard ford
Axle - 11 = ford 9" 3.7 ratio non LS 3.3M rating
Max. G.V.W. lbs - 05000 = Maximum vehicle can weigh with load and passengers.
Cert - 114 + Net Horse power the 223 produced
H.P. R.P.M. - 3600 RPM where the 223 produced the 114 HP
D.S.0. - 61 = Dallas Texas. Where the dealer ordered the truck from.
Welcome to FTE and "66" ownership.
Garbz
F10= F100
J= 223 inline 6
Garbz
F10= F100 2WD
Trans - A = Ford type 3.03 3 speed manual all syncromesh transmission.
Axle - 11 = Ford 9" - 3.70-1 - no Limited Slip - 3,300 lbs rear axle capacity.
Could have been sold as a Cab & Chassis, Open Drive-Away Chassis & Cowl or Cowl & Windshield. Bolh: No bed, no cab, just a dashboard, floor pan, bare frame rails behind it, fuel tank located on left frame rail.
Model code F10J is correct for 1957/62's, refers to F100 2WD, 5,000 lbs. GVWR
114" Wheelbase and that's it. You cannot say short bed because there's no way to know if these trucks came with any bed originally or not. VIN Series code (1st 3 digits) doesn't decode to pickup until 1973.
So, I thought the OP had a 1966, no Uni's after 1963. 66 in this context refers to Uni body style.
Maybe he was also hinting that the OP should consider posting in the "66" section since posts in the "Uni" section often sit there for weeks with no response!
pupcar
05-15-2014 10:18 PM
Charlie_in_OC
09-17-2013 06:02 AM
Phreezerburn
08-12-2012 11:27 AM
strong17
05-05-2009 05:25 PM
