Is it the IPR sensor again ?!?!?!
Should I replace the IPR or the ICP or both? Help!
Ok, I changed the ICP sensor about a year and a half ago. Then I performed the EGR delete and Oil Cooler rebuild. Shortly after that, I began experiencing surging and a complete engine shut-down. After some very helpful insight from the forum, I replaced the IPR valve about a year ago and all was well. Until recently, now the random surging has begun again. There have been several instances where, if I had been little slower fully depressing the break, I would have rearended the vehicle in front of me. Then I pulled in from work one day, turned the wheel and mashed the break and the truck cut-off. Following this, everything seemed to clear-up. Then, the surging returned and, while waiting on a train, the truck surged hard and died. It did start right back up and ran normal. From past experience, it appears to be doing the exact same thing it did before I changed the IPR last time. Any suggestions?
Thanks in advance!
GH
Thanks in advance!
GH
It is an '03 build so the ICP is under the turbo. I replaced the sensor (ICP and IPR) as well as the pigtail about a year ago. No, I haven't had it scanned yet. The last time it happened, the ICP triggered the CEL but the truck ran fine. When the IPR went out, it was very noticeable (surging, lurching, RPM fluctuations, shut downs . . . the same thing it is doing now).
Thanks for the reply! ! !
I have similar symptoms but am trying a used ecu tomorrow. Also cat was clogged solid. Crazy!
I'm sure it was supposed to be EBP. After a long day in the Texas heat I don't think typing is a priority for Moe.
Will a local parts store ODB-II pick up the trouble code related to any of these issues (ICP, IPR, EBP, etc) or will I need to take it in to have the code read and cleared? The issue randomly occurs and only typically happens while either driving or sitting still at a light. It has only acted up once sitting still in the parking lot.
Autozone could not read any codes since a CEL was not present.
The weird thing is, the truck has not acted up again since before my last posting. Any ideas?
Should I proceed with changing the ICP sensor just in case?
The worst issue I had was while parking the truck and it cut off. I restarted it and it idled up and down and sputtered a few times. I gave it some fuel and it spewed a black cloud out the tailpipe.
I am open to ideas / suggestions as to what to replace / do at this point.
Thanks!
GH
Thanks!
GH
joe blow
09-04-2015 12:53 PM
Tampa250
03-26-2015 01:44 PM
Sixgunjack
03-16-2014 11:17 AM
