I went and did it
#781
Sharp eyes.
Nope your not seeing things.
Now that I've had the truck down this far I've learned that the cab will need to come off in the future.
There is some rust in the cowl area. And one of the mounts has stress cracks (same side). Not only this one but in the cab also. They're not a problem right now but will be addressed later.
I had planned to pull the bed at least but now it looks like I'll do the whole deal.
But for now, I'm running' it.
Edit
Went out and took a wire brush to it cause it was buggin' me.
Surface rust crack.
Here's the crack in the mount. No problem it's in the out shell. Inner is fine.
Runnin' it.
Thank you sir.
Just trying to live up to your (and others) example.
Edit
Surface rust crack.
Runnin' it.
#782
Alrighty, we are officially wired.
Lights work with their new harness and nothin' burnt down.
Won't be long now.
Just have to finish the steering, mount a carb and fire this bad piece up
I've run out of harness covering so cleanup has to wait. I have two different kinds and just because I'm using what I have, it's been woven for the big stuff and ribbed for the smaller stuff. It actually doesn't look to bad.
Mounted the vacuum canister. It's a Comp cams piece from Summit. Nice. Took the sticker off.
Gonna mount the passenger side fender and button that side up for the last time.
Won't be long now.
#786
#788
#789
#791
#793
#795
Yeah, agreed. It's in a place I can get to any time.
Just trying not to get distracted.
Trying to stick to my plan of not getting bogged down with the old " you know, as long as I'm here I may as well do.........".
That is the road to ruin if you're trying to keep your truck in running condition.
It'll still be there in a couple months.
