why my front tires wear out edges? - Ford Truck Enthusiasts Forums
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Old 03-25-2003, 12:29 PM
itsabroken itsabroken is offline
itsabroken is starting off with a positive reputation.
Unhappy why my front tires wear out edges?
94 F150 2 wheel drive; installed new
front <a href="http://service.bfast.com/bfast/click?bfmid=37919709&siteid=39251846">tires </a>- wears outside edges quickly- am I in need of something like a frontend alignment? took it into a shop, they said that is normal for all ford's with I beam suspension. Am I getting the truth or is there something I can do?
snowballed
Old 03-25-2003, 12:52 PM
res_q_me2001 res_q_me2001 is offline
res_q_me2001 is starting off with a positive reputation.
yeah i would say bull id go get an alignment no manufacturor is going to allow that for one unusual tire wear is a safty hazard you might want to see if their is a recall on your truck
Old 03-25-2003, 04:10 PM
bronco351 bronco351 is offline
bronco351 is starting off with a positive reputation.
Hi, how about use some periods in your reply so we can understand them!! Thank You!
Old 03-25-2003, 11:12 PM
Starratt04 Starratt04 is offline
Starratt04 is starting off with a positive reputation.
hey you probbaly need to get a camber adjustment. it sounds like thier maybe bowed a little bit if just the out side of the tire is wearing.
Old 03-26-2003, 09:07 AM
Yeah, sorry about the whole period thing. I talked to a guy i know at a ford dealership. He said he has seen the problem before. He said that an alignment is all they do for it and it usually fixes the problem.
Old 03-28-2003, 07:56 PM
RedXL's Avatar
RedXL RedXL is offline
RedXL is starting off with a positive reputation.
I've have the same problem on my 93 F150 4x4. I asked my father (he's a mechanic) and he said that the steering linkage on this particular generation of Ford trucks is very poorly designed and allows for terrible bump-steer. He suggested that I should align the front end to have about 1/16th tow out and the tire wear would not be as great.
Old 03-28-2003, 08:23 PM
BigMattXXL's Avatar
BigMattXXL BigMattXXL is offline
BigMattXXL is starting off with a positive reputation.
Arrow why my front tires wear out edges?
I'll put in another vote for Alignment.
XXL
Old 03-28-2003, 10:46 PM
MustangGT221's Avatar
MustangGT221 MustangGT221 is offline
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
If the wear is on both sides, it oculd also be air pressure. If the <a href="http://service.bfast.com/bfast/click?bfmid=37919709&siteid=39251846">tires </a>are underinflated, the edges will wear out quicker. Alignment is usually one side or the other, not both.
Old 03-29-2003, 01:38 PM
fordmudrunner2020 fordmudrunner2020 is offline
fordmudrunner2020 is starting off with a positive reputation.
We had the same problem on our 96 F-250 4x4. The outside edge on the passenger side went bald quite quickly. So we took it to the dealer and they gave it a wheel alignment and we haven't had a problem since. Some people though tried to tell us that it was from turning at high speeds which we do not do.
Old 04-25-2003, 12:44 PM
ClydeSDale's Avatar
ClydeSDale ClydeSDale is offline
ClydeSDale is gaining momentum as a positive member of FTE.
Twin I-beams have always had a tire wear problem dating back to '65. 4X's were usually the worst. With some trucks there didn't seem to a 100% cure ... align, re-align, heat and bend the beam, cold bend the beam, different shocks and even then the best cure was rotating the tires on the rims occassionally to even out the wear.
Find a shop that knows Twin I-beams and they'll help you out.
Old 04-25-2003, 04:47 PM
mrwizard's Avatar
mrwizard mrwizard is offline
mrwizard is starting off with a positive reputation.
They can also be "within factory spec's" and still wear the tires fast. My '95 4X4 is "within spec's" but looks funny and is wearing the inside of the tires like crazy because of the negative camber. As I type, it's in the shop now getting a different brand of axle drop brackets installed to correct the lift kit induced camber problem. Then they are going to weld the cracked crossmember back together and weld the crossmember to the frame because the rivets are loose.
Old 04-25-2003, 06:31 PM
What you can do is the chalk test. Make sure your tires are at proper PSI from the rating on the door jam sticker. Put a line about an inch wide accross all of your tires. Drive it a little bit in a parking lot and check the wear of the line. If the line wears more in the middle than on the outsides, decrease air pressure. If it wears on the outside more than the middle, increase air pressure. You can only do so much with an alignment, air pressure in the tires is a big determining factor for tread wear. You want that chalk line as evenly rubbed as possible for maximum tread life.
It's been too long; Breakfast G2G Sept 18, 8AM wpnaes S. California Chapter 33 12-23-2016 11:51 PM
wicked bad tire wear jtorsey91 1987 - 1996 F150 & Larger F-Series Trucks 5 08-24-2016 12:04 AM
tire wear olyellow Ranger & B-Series 2 10-04-2014 10:40 AM
Bad ball joints? WVF150VIANC 3.8 & 4.2L V6 10 03-07-2005 01:39 PM
Pic Request: F-250/350 10+" lift, 40+" tires (99-05) Customz 1999 to 2016 Super Duty 21 09-27-2004 09:56 AM
Tags
2006, edges, f250, ford, front, inside, tires, truck, wear, wearing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
