You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
5W20 Motorcraft with Motorcraft filters. Follow the oil-life indicator for change intervals.
__________________ 2002 F-250 XLT SC LB 4x4 7.3L PSD - SOLD
2004 F-250 XLT SC LB 4x4 5.4L ZF6 - SOLD "Our foreign policy WILL change eventually, as Rome's did, when all budgetary and monetary tricks to fund it are exhausted."
- Ron Paul
The Motorcraft oil filters are very good filters at a very good price, I use them. As for oil, in the warrenty period I would use the oil weight recommend by Ford. You can use a good name brand oil that meets Fords specs if you want, you do not have to use Motorcraft oil.
__________________
"The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants." (Thomas Jefferson)
I test my oils at each change for last 3 years and the Motorcraft dealer put into my PowerStorke was the worse oil ever. After 5000 miles it show worse, than Rotella after 10,000
We are talking about non-diesel oil in the thread, but really, that bad?
- Ron Paul
All manufactures use the same base oil with some chem pack modifications between oils for diesel and gasoline engines. If any..
This way, or the other I strongly recommend do your own test. There are millions myths about oil change for each opinion based on actual testing.
With the cost of oil changes on our engines, the $25 for lab test seems to be a bargain. You will get your money back if they allow you extend the interval by only 2000 miles.
I used Valvoline 5W20 full Synthetic and a Fram tough guard oil filter for my first change.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
