1978 - 1996 Big Bronco
Clutch not fully engaging properly?
Old 06-01-2011, 02:35 PM
garydmundy's Avatar
garydmundy
garydmundy is offline
1994 Bronco aftermarket 351 with Mazda 5 speed and hydraulic clutch. Recently the clutch does not seem to completely engage when the clutch is pressed to the floor. It is very hard to get into first gear (sometimes I can't even get it into 1st), slight grinding when upshifting in all gears and real grinding when shifting into reverse. This has come on gradually. I have checked the fluid level in the master cylinder and it was low but now out. I filled it but no improvement. The other thing the clutch pedal sometime won't come all the way back and I have to use my foot to pull it back to its resting position. Any suggestions?
Old 06-01-2011, 02:44 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
sounds like the slave cylinder is bad or you have air in the line and it needs bleed.
WilliamKG88
1983 - 2012 Ranger & B-Series
04-20-2016 01:41 AM
tananaBrian
1999 to 2016 Super Duty
10-09-2015 05:51 PM
Frantz
08-15-2015 01:11 PM
mklemin
03-13-2008 12:15 AM
lee
05-17-2002 02:53 AM
Quick Reply: Clutch not fully engaging properly?
