Soft Sinking Brake Pedal - Ford Truck Enthusiasts Forums
Old 06-01-2011, 02:00 PM
bryansshort's Avatar
bryansshort bryansshort is offline
bryansshort is starting off with a positive reputation.
I have replaced the front callipers, disc's and pads, plus the rear shoes, cylinders and fluid. The pedal continues to sink to the floor under heavy braking. What next, master cylinder?
Any thoughts gladly received.
Old 06-01-2011, 02:47 PM
Tsoptich's Avatar
Tsoptich Tsoptich is offline
Tsoptich is starting off with a positive reputation.
Since you already replaced everything I would recommend pulling the maste out and doing a good bench bleed only take you about an hour and if need to replace you have half the work done. But if you do replace it bleed it first you can do it yourself with a friend put it in a vise so it's level or take it to a tire service shop we do them for customers for half hour labor about $30. Good luck.
Old 06-01-2011, 03:05 PM
BlueOvalBud's Avatar
BlueOvalBud BlueOvalBud is offline
BlueOvalBud is starting off with a positive reputation.
This sounds similar to my issue, but I already did put in a used master cylinder that came from another truck that had good brakes. We had chain-towed the truck home and without the engine running and no vacuum, it still stopped better than my truck.
My buddy has an 86 IDI and he is starting to develop the sinking pedal at stop signs/lights. His truck has an automatic, and he says if the light is long enough, the pedal will eventually sink to the floor and not hold the truck. They are mechanics and say it's the vacuum pump. Part is on order, we'll see what happens.
Old 06-01-2011, 03:23 PM
38Chevy454's Avatar
38Chevy454 38Chevy454 is offline
38Chevy454 is starting off with a positive reputation.
Symptoms of leaking seals in master cyl are the pedal sinks under light pressure, such as at a light. If you hit the pedal hard it usually will not sink, until you let up on it. I think you need to get a new master cyl based on your description.
Old 06-01-2011, 03:25 PM
swooshcmk swooshcmk is offline
swooshcmk is starting off with a positive reputation.
I agree on needing a new master. Even if you had no vac pump at all the pedal shouldn't sink.
Old 06-01-2011, 04:02 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
If you had no vac pump the brake would never sink lol. once you loose that your using the power of your leg(squats and whatnot come in handy for this) to stop. Trust me...left walmart didnt know why the brake light was on then i tried to stop lol....ended up damn near hitting someone(thank god for manual transmissions) and replaced belt next day haha.
Old 06-01-2011, 05:31 PM
Quote:
Unfortunatly I am an amputee and my remaining leg hasn't got much power as it was badly smashed too so I rely on power assistance.
Old 06-01-2011, 05:53 PM
Maybe I was misunderstood or maybe I'm misunderstanding...
vacuum boost or hydroboost it doesn't matter, they only assist you in applying braking force. Neither one has an effect with the pedal slowly leaking pressure and going to the floor. You should be able to stand on the brakes holding pressure all day long, just as if you didn't have any power assist at all. Even if your vacuum booser isn't working properly, you should still be able to apply pressure all day long. If your vacuum pump isn't working, you should still be able to apply pressure all day long.
If the pedal slowly sinks when just sitting still, you're either leaking fluid externally, or it's leaking past internally in the master cylinder.
By all means keep your power assist. I'd hate to think what a chore it'd be to stop these beasts w/o any assist at all.
Old 06-01-2011, 07:47 PM
monte97z's Avatar
monte97z monte97z is offline
monte97z is starting off with a positive reputation.
got the same problem, i replaced master cylinder, pads, rotors calibers, and rear shoe parts kit(all springs, and adjusters) bleed everything till i got fresh fluid out all bleeders then re-bled the system. pedal is still soft and will slowly sink to floor with constant pressure and i got week brakes. im at a loss, so i been just giving my self plenty of distance, normal stopping is ok, but emergency stopping is not happening.
Old 06-01-2011, 08:36 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Like everyone said, does like master cylinder related.
Kind of off topic question but I have to.
What vehicle are we talking about? Is it the class C camper in your avatar pic?
If so, if you can, post a large pic of it, I find that overcab bunk looking pretty interesting, never seen on with a window like that.
Old 06-01-2011, 08:41 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
front rubber caliper lines and rear wheel cylinders can also be the cause for a weak brake peddle.
Old 06-01-2011, 09:36 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
A bad rabs valve can cause sinking pedal just like a MC... seen it several times.
Old 06-02-2011, 06:28 AM
Have put up 3 pics in an album, tell me what you want to see and I'll post more.
Old 06-02-2011, 09:24 AM
smithf250's Avatar
smithf250 smithf250 is offline
smithf250 is starting off with a positive reputation.
My truck was doing the same thing a few months back and it was the master cylinder.Changed it out and the problem was solved. Thanks to everyones help on here it was fixed within a day!!!!!
sinking brake pedal still !!!! Greg5OH Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 22 01-04-2013 09:06 PM
Brake pedal goes soft lgwilson 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 04-20-2011 12:55 PM
Sinking Brake Pedal - PLEASE HELP PureGrunt Brakes, Steering, Suspension, Tires, & Wheels 4 03-29-2010 01:44 AM
spongy brakes/brakes hanging on Blaine Schulte Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 09-19-2003 11:25 AM
losing brake pressure jrs_big_ford_f150 Brakes, Steering, Suspension, Tires, & Wheels 8 10-20-2002 05:22 PM
Tags
1984, 1994, 4x4, 69l, 86, brake, cylinder, diesel, e350, f250, ford, kit, master, navigator, pedal, rebuild, sinks, soft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
