Upfitter Switches - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Upfitter Switches
Old 06-01-2011, 10:52 AM
DirtEngineer DirtEngineer is offline
DirtEngineer is starting off with a positive reputation.
Upfitter Switches
Hey all,
I know there are other threads in other forums on uses for the upfitters, but I'm curious what folks here are using theirs for (seeing as high-idle isn't really necessary for the gasser).
I'm getting a topper installed next week, and I was thinking about running some extra lights into the box. I'd also like to hook up some aux lights on the back bumper for hitching up to the trailer. Has anyone else run lights back to the box? How did you route the wiring from under the hood back to the box?
Thanks.
Old 06-03-2011, 11:11 PM
n7bsn n7bsn is offline
n7bsn is starting off with a positive reputation.
If I had them...switching power for Ham Radio "stuff"
Old 06-03-2011, 11:29 PM
kmonty2's Avatar
kmonty2 kmonty2 is offline
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
I was thinking about adding some lights in the bed. So I can see at night under the cover.
Old 06-04-2011, 08:56 AM
Beach_Bob Beach_Bob is offline
Beach_Bob is starting off with a positive reputation.
I keep a back up alarm wired to a switch. It adds a lot more flexibility to the alarm than if it had been wired into the reverse lights (i.e. no alarm when I back off my driveway)
Old 06-04-2011, 04:09 PM
bcham5's Avatar
bcham5 bcham5 is offline
bcham5 is starting off with a positive reputation.
aux1= 2 lightforce 170s aux2=2 lightforce 170s aux3=Wilson cellular booster aux4= 2-way radio
Old 07-17-2011, 08:10 PM
2011SD's Avatar
2011SD 2011SD is offline
2011SD is starting off with a positive reputation.
I use mine for 2 Hella 500FF friving lights mounted in the front bumper on switch#1,2 aux reverse lights mounted on the hitch switch #2,and my aftermarket backup camera off switch #3,I also added aux lights inside my cap but did not run them off of an upfitter tapped off of the hot wire for my 3-12v outlet block in the cap these lights can be rotated back for extra light outside of the cap also.
Old 07-18-2011, 01:31 PM
SturgeonHunter's Avatar
SturgeonHunter SturgeonHunter is offline
SturgeonHunter is starting off with a positive reputation.
aux1= smoke screen
aux2= oil slick
aux3= tack strips
aux4= marbles
Sorry.....my kids think it's funny.
Old 07-18-2011, 10:49 PM
socapots socapots is offline
socapots is starting off with a positive reputation.
Quote:
Originally Posted by SturgeonHunter View Post
aux1= smoke screen
aux2= oil slick
aux3= tack strips
aux4= marbles
lol.. they right. it is. haha.
only thing i plan for is fog lights, lights in the bed after i get a cover, and maybe to switch off the sub amp if the need arises..
Old 07-19-2011, 03:54 AM
mlb4966's Avatar
mlb4966 mlb4966 is offline
mlb4966 is starting off with a positive reputation.
Aux 1 = Power supply to Relay for Lightforce 240 - Center Set
Aux 2 = Power supply to Relay for Lightforce 240 - Side of road "Moose Lights"
Both Relays are turned on by activation of the high beams.
Aux 3 = OPEN (Like the above mentioned "Smoke Screen" - Maybe mosquito foger)
Aux 4 = Power supply to Relay for Aux Back up lights - Long winter nights make this a necessity for hooking up trailers.
Old 07-19-2011, 09:41 AM
2011SD/Mike B,
I'm curious how you routed the wiring back to the box for the Aux back-up lights? I'm a rookie at vehicle electrical wiring, and I'm not sure how to route the wires back to the box.
Thx
Old 07-19-2011, 10:12 AM
2011SD's Avatar
I ran a hot wire along the passenger side frame and up along the firewall on the passenger side to the battery. I did use a wire loom to keep the wire protected. I ran the ground to the bolt I mounted the lights with. Then I used the pass through wire on the driver side to get into the cab.
2015 upfitter & CB radio whooboy 6.7L Power Stroke Diesel 40 05-14-2016 05:45 PM
2014 F350 upfitter switch wire location. tjc transport 1999 to 2016 Super Duty 7 12-07-2014 11:12 AM
2011 F250 - Trouble Shooting Upfitter Switches E077528 1999 to 2016 Super Duty 2 10-25-2014 05:00 PM
UPFITTER SWITCHES WHAT'S HOOKED TO YOURS? 11superduty 6.7L Power Stroke Diesel 69 07-19-2014 11:01 PM
Upfitters Switches (adding second set) Moon's Dad 1999 to 2016 Super Duty 3 04-29-2011 10:03 PM
Tags
2009, 2011, alarm, aux, aux1, back, connection, f250, ford, lightforce, lights, start, switch, switches, trucks, upfitter, wire, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
