Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Michigan Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: just another truck
  #1 (permalink)
Old 06-01-2011, 04:26 AM
just another truck's Avatar
just another truck just another truck is offline
Michigan FTE Chapter Lead
Garage is empty, add now
just another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputation
The June BS thread...
Lets hope June is lucky for all the farmers!!!!!
Good Morning, coffee is on.. AC is on...and off to work I go..Taking all I have to go in today to, I need to catch a break on this damn vacuum furnace I have been working on.. oh well..
  #3 (permalink)
Old 06-01-2011, 05:16 AM
Downsea's Avatar
Downsea Downsea is offline
Downsea is gaining momentum as a positive member of FTE.
Good morning all. Here's to a good day Pat!
__________________
Chris
2002
  #4 (permalink)
Old 06-01-2011, 06:20 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
Well June is starting off good. Good weather, good workout this morning, and back to work.
Hopefully less rain this month, it's a killer trying to keep the truck clean.
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #5 (permalink)
Old 06-01-2011, 07:42 AM
jimmyv13 jimmyv13 is offline
jimmyv13 is starting off with a positive reputation.
Jim Veillette
I had a chance to look at the green truck this last weekend. It looks to be in pretty good shape. The DS bumper bracket is slightly bent making the bumper sit about 1/4" higher. No frame damage, just a bent bracket what can be straightened out with a BFH or simply replaced. The dealership will let me know today if they accept my offer. They came back with $17,9 OTD with the 05 bumper. I offered same price with the 08 bumper and I'll do the cab lights. Sooooooooo, here I sit.........waiting.
Incidentally, I ran an Oasis on the black 05 F350 and it came back as a blue 04 F250. I didn't even go look at it yet...I'll wait to see if the green truck falls through. I'm gonna low ball the F250 and see what he says. It needs some work to make it right and doesn't have a couple of things I would like, but if the price is right, I can't put up with a few missing creature comforts.
OASIS on the green F350:
VEHICLE DESCRIPTION: 2005 F-SERIES
BODY STYLE: F-350 CREW CAB 4X4
ENGINE: 6.0L DIESEL DI V8
TRANSMISSION: TORQSHIFT
AXLE CODE: 3L
ENGINE CALIBRATION
PAINT COLOR: DK GREEN SATIN WB
RADIO: AM/FM STRO/CD CHANGER/CLK
GROSS VEHICLE WEIGHT: 11,400 LB. GVW
AXLE RATIO: 3.73 FINAL DRIVE RATIO
WHEEL SIZE: 8X18" FORGED POLISHED ALU WHL
FRONT TIRE: LT 275/70R18E A/T OWL
1FTWW31P05EC47244
Miles 5
GREAT LAKES FORD LINCOLN OF MUSKEGON Ph: 231-7772750 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:14-APR-2005 Doc #:15394701
Cust Comments: CUSTOMER STATES VEHICLE SHAKES AT HIGHWAY SPEEDS
Tech Comments: TEST DRIVE AND VERFIY CONCERN AND PERFORM NVH DIAGNOSIS AND CHECK TIRES AND BALANCE ALL FOUR WHEELS AND TEST DRIVE
1FTWW31P05EC47244 T
miles 17148
STANTON FORD, L.L.C. Ph: 989-8318388 St:MI
Repr Date:15-DEC-2005 Doc #:02263603
Cust Comments: LEFT LIS LIGHT WILL NOT WORK
Tech Comments: DEFECTIVE BULB
1FTWW31P05EC47244
miles 17148
STANTON FORD, L.L.C. Ph: 989-8318388 St:MI Ctry Cd: USA Reg Cd: NA
Repr Date:15-DEC-2005 Doc #:02263601
Cust Comments: IDLES ROUGH , SMOKES, POOR FUEL MILEAGE
Tech Comments: DEFECTIVE EGR VALVE
1FTWW31P05EC47244
miles 25083
STANTON FORD Ph: 989-8318388 St:MI Ctry Cd: USA Reg Cd: NA
Repr Date:30-MAR-2006 Doc #:02352101
Cust Comments: RECALL 05B32
Tech Comments: DEFECTIVE DEGAS BOTTLE
1FTWW31P05EC47244
miles 25083
STANTON FORD Ph: 989-8318388 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:30-MAR-2006 Doc #:02352102
Cust Comments: 05B35 RECALL
Tech Comments: DEFECTIVE PROGRAMING
1FTWW31P05EC47244
miles 95035
KENT CITY FORD, INC. Ph: 616-6784631 St:MI Ctry Cd: USA Reg Cd: NA
Repr Date:20-OCT-2008 Doc #:274842A
Cust Comments: HAS OIL IN COOLANT
Tech Comments: 95035 PERFORMED INSPECTION SUSPECT OIL COOLER INTERNAL LEAK, REPLACED OIL COOLER AND EGR COOLER, FLUSHED COOLANT TWICE CLEANED WITH TIDE, ROAD TESTED AND REFLUSHED COOLANT, RECOMMEND ANOTHER COOLANT FLUSH WITH NEXT OIL CHANGE, REPLACED CAC TUBES, LEAKING OIL, REPROGRAMEND PCM, TCM AND FICM, TO LATEST CAILIRATION., CHANGED ENGINE OIL TOPPED OF WITH STRONG MIX OF
1FTWW31P05EC47244
miles 96304
Repr Date:12-NOV-2008 Doc #:275223A
Cust Comments: VEHICLE ACTS LIKE IT IS LOADING UP AND DOES NOT LIKE TO TAKE OFF CHECK AND ADVISE
Tech Comments: 96304 TESTED EEC V SYSTEM, DTC P0405, P0404. TESTED AND REPLACED EGR VALVE AS PER TSB 07 21 09. NO COKING PRESENT, VALVE SENSOR IS INTERMITTENT OPEN CIRCUIT. CLEARED DTCS, RETEST, OK.
1FTWW31P05EC47244
miles 133638
VANDERHYDE BROTHERS FORD, INC. Ph: 616-6961541 St:MI Ctry Cd: USA Reg Cd: NA
Repr Date:08-MAR-2010 Doc #:109364A
Cust Comments: CUSTOMER STATES NO POWER AT TIMES
Tech Comments: 133638 9F452 42 TEST DROVE AND VERIFIED CONCERN INTERMITTENLY THE ENGINE HAS LOW POWER AND BLACK SMOKE FROM THE EXHAUST PREFORMED PRECHECKS AIR INTAKE FUEL AND OIL ALL PASSED PREFORMED KOEO SLEF TEST RECEIVED MEMORY CODE P0404 REFER TO PINPOINT TEST W1 HAD CODE P0404 W2 NO OTHER CODES W3 PREFORMED EGR SYSTEM TEST FOUND EGR VALVE SLIGHTLY OPEN AND WOULD NOT COMPLETE TEST REMOVED
1FTWW31P05EC47244
miles 133638
Repr Date:08-MAR-2010 Doc #:109364B
Cust Comments: CUSTOMER STATES THE VEHICLE RUNS ROUGH
Tech Comments: 133638 9E527 42 TEST DROVE VERIFIED CONCERN ENGINE RUNS ROUGH INTERMITTENLY PREFORMED PRECHECKS AIR INTAKE FUEL AND OIL ALL PASSED PREFORMED KOEO SELF TEST RECEIVED MEMORY CODE P0263 REFER TO PINPOINT TEST P1 HAD P0263 P9 PREFORMED CYLINDER CONTRIBUTION TEST FOUND CYLINDER 1 WEAK ALL OTHERS OK P10 PREFORMED RELATIVE COMPRESSION TEST ALL CYLINDERS EVEN NO
OASIS on the advertised "'05 black F350"
VEHICLE DESCRIPTION: 2004 F-SERIES
BODY STYLE: F-250 CREW CAB 4X4
AXLE CODE: C1
ENGINE CALIBRATION
PAINT COLOR: MEDIUM WEDGEWOOD BLUE
RADIO: ELETR PREM AM/FM STRO/DISC
GROSS VEHICLE WEIGHT: 8800 LB. GVW
WHEEL SIZE: 7.0 X 16" CHROME CLAD STL WHEL
FRONT TIRE: LT235/85R-16E OWL A-T
1FTNW21P24EC16551
miles 31332
GRAND LEDGE FORD LINCOLN Ph: 517-6278100 St:MI Ctry Cd: USA Reg Cd: Repr Date:03-NOV-2005 Doc #:045383D
Cust Comments: RECALL 05E15 EXH PRESSURE SENSOR
Tech Comments: 31332 RECALL #05E15 W INSPECTED VEHICLE, REPLACED EXHAUST BACKPRESSUR E SENSOR, REPLACED PIGTAIL CONNECTOR, ALSO REPROGRAMMED PCM, FICM, AND TCM
1FTNW21P24EC16551
miles 31332
GRAND LEDGE FORD LINCOLN Ph: 517-6278100 St:MI Ctry Cd: USA Reg Cd: NA
Repr Date:03-NOV-2005 Doc #:045383B
Cust Comments: RECALL 05B29 CHARGE AIR COOLER
Tech Comments: 31332 RECALL #05B29 W PERFORMED 05B29 RECALL, REMOVED OLD CHARGE AIR COOLER DUCT, REPLACED WITH NEW AND TORQUED TO SPECS
1FTNW21P24EC16551
miles 31332
Repr Date:03-NOV-2005 Doc #:045383E
Cust Comments: 59B01 ONE TIME CUSTOMER ASSURANCE TEST DRIVE
Tech Comments: 31332 RECALL #05B01 W PERFORMED ONE TIME CUSTOMER ASSURANCE TEST DRIVE
1FTNW21P24EC16551
miles 31332
Repr Date:03-NOV-2005 Doc #:045383A
Cust Comments: RECAL 05S34 FUEL INJ CONTROL WIRE HARNESS
Tech Comments: 31332 RECALL #05S34 W PERFORMED 05S34 RECALL, REMOVED FICM, INSPECTED WIRING, FOUND NO CHAFING, INSTALLED PROTECTIVE COVERS AND SHIELDING, REINSTALLED EVERYTHING
1FTNW21P24EC16551
miles 52723
Repr Date:13-NOV-2006 Doc #:057875A
Cust Comments: CHECK ENGINE LIGHT ON AND WONT STAY RUNNING
Tech Comments: 52723 CHOKED EGR AND TURBO AND FICM REPROGAM INSPECTED AND ROADTEST VERIFIED LOW POWER AND STALL AND MIL LIGHT ON OIL LEVEL PASSED CLEAN AND SUFFICIENT FUEL LEVEL PASSED KOEO CODES P0269 P0404 P0299 BUZZ TEST PASSED RUN OASIS AND FOUND TSB 06 18 3 TEST SYSTEM INTAKE RESTRICTION PASSED EGR POSITION FAILED 2.20 VOLTS SPEC 06 1.20 VOLTS EGR STUCK OPEN REMOVED EGR VALVE AND CLEANED AND
1FTNW21P24EC16551
miles 137759
KRAPOHL FORD LINCOLN MERCURY CO. Ph: 989-7722991 St:MI Ctry Cd: USA Reg Cd: NA
Repr Date:30-JUL-2010 Doc #:145569A
Cust Comments: EGR COOLER LEAKINGOTC INVOICE #614090,DATE 07 02 2010
Tech Comments: REPLACE EGR COOLER
__________________
2005 F-250 Lariat CC FX4 6.0L
4" MBRP Turbo Back*High Idle*Blue Spring*Updated Stand Pipes, Dummy Plugs*SGII w/Blendmount*Sinister Coolant Filter*SRL*'10 Tailgate*2" level*Dicad EGR delete*Premium EdFICM*Powerslot Rotors*Hawk Pads*Riffraff boots*DIY CCV*4" Rear Blocks
  #6 (permalink)
Old 06-01-2011, 07:43 AM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
2005 Ford Excursion
X_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputation
Happy JUNE to my Northern Neighbors!
Come on Summer Solstice!!!
Have a great MONTH everyone!!!
Joe.
__________________
2012 Jeep Liberty 4dr 4WD (toad)
2007 Tiffin Phaeton 40' QSH DP with 350HP Cat C7 (4 slides 3 women just right! )
Big BS'r #19 and Slackmaster #30
  #7 (permalink)
Old 06-01-2011, 07:44 AM
mY FINGERS ARE CROSSED FOR YOU!!! Sorry for the caps, just had to log in to a app here at work..
  #8 (permalink)
Old 06-01-2011, 10:36 AM
Toyman's Avatar
Toyman Toyman is offline
Toyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to beholdToyman is a splendid one to behold
toyman
Happy to see June and a sunny sky.
Looks like everyone had a safe weekend. We did, 3 days of relaxing and playing was needed. Worked on getting the pool ready to open, should be ready by Saturday
So when is the next GTG??? or beer gathering one night after work.
__________________
Hi my name is Rich, I am a cornerholic..........
2004 F150 Supercrew Lariat, 3V-5.4L. Daily Driver.....
2004 Jeep LJ Unlimited. 4.0L, auto.....modifications to follow.
  #9 (permalink)
Old 06-01-2011, 10:55 AM
Jim Veillette
If I get this truck, I wouldn't mind attending the G2G.
__________________
  #10 (permalink)
Old 06-01-2011, 11:41 AM
Downsea's Avatar
I don't know about the black one anymore Jimmy. Green one had probs but they were taken care of. Like Pat said.
__________________
Chris
2002
  #11 (permalink)
Old 06-01-2011, 12:08 PM
Jim Veillette
Yeah, I had a bad feeling from the start on that black one...
__________________
  #12 (permalink)
Old 06-01-2011, 01:14 PM
SDElwood's Avatar
SDElwood SDElwood is offline
In corner drinking beer.
2000 Ford F-350
SDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud ofSDElwood has much to be proud of
https://www.facebook.com/mike.blackport
Would you like me to cruise over and look at the black one? You can just call me as well. Or we'll wait and see how the green one turns out.
__________________
Mike -
2000 4x4 CC LB F-350 7.3L SuperChips Flashpaq, 4" turbo back exhaust, 6637.
Quote:
Originally Posted by Toyman View Post
Dude you get thirsty at mid swallow of your beer, don't hide it.......
  #13 (permalink)
Old 06-01-2011, 01:41 PM
Jim Veillette
It's entirely up to you...maybe I'll wait to see if the green one doesn't work out since that is definitely my first choice.
__________________
  #14 (permalink)
Old 06-01-2011, 01:54 PM
fordtruckman's Avatar
fordtruckman fordtruckman is offline
fordtruckman is a name known to allfordtruckman is a name known to allfordtruckman is a name known to allfordtruckman is a name known to allfordtruckman is a name known to allfordtruckman is a name known to all
Quote:
Originally Posted by sddesigns View Post
Good Morning MI!
Happy Hump Day!
Dang Steve 71k posts. That's impressive!
Happy Wednesday and finally we have warm weather!
__________________
Matt | 2004 F150 SCAB 4.6l 4x4 |
[url=http://www.fuelly.com/driver/MatthewSimmons08/f150]
  #15 (permalink)
Old 06-01-2011, 02:05 PM
I have the furnace tuned it at 1100*!!!!!!!
need to check her out at 1550, and 2150..but 1100 degrees is in!!!!!
time to go home and enjoy the corner
Tags
05b01, 2007, assurance, diagnosis, drive, expedition, ford, nvh, recall, test, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
