ND Archived Buy/Sell/Trade Ads
on
Chapter Buy/Sell/Trade Ads: Each chapter will have one (1) thread for chapter members to list items wanted, for sale or for trade. The rules for posting in this thread are as follows:
- Only Ford truck related items and automotive tools & equipment can be listed.
- Only one picture is allowed per post, per item. If additonal pictures are necessary, place a link in your post to those pictures. Additional posted pictures will be removed without warning.
- You must have your private messaging (PM) turned on and be able to receive PM's to post an ad in the Chapter thread. If you do not, your post will be removed.
- Use the PM or email system to conduct all discussion and transactions regarding the item(s). You can post your interest in the item(s) and that you’ll contact the seller but no discussions. Keep it short.
- If you post an ad, please reply that you found, sold or otherwise disposed of the item.
- The buy/sell/trade thread will be purged periodically for old postings. Generally every 30 to 60 days.
- You need to be an active Chapter Member on FTE to post a wanted, for sale or for trade item(s). No Exceptions.
- You must have permission from the Chapter Leader or a Regional Moderator to post an ad in a chapter that you are not a member of.
- If you are new to FTE (less than 15 days) or have less than 25 posts, you must contact the Chapter Leader for permission before posting an ad.
- Your ad or reply to any ad is subject to editing or deletion at discretion of the Chapter Leader, Moderators or Administrators of FTE.
- Commercial advertisements are strictly prohibited.
i just figured i would post this here in case anyone was interested, ill give an good fte discount if any members here are interested.
9.5 foot pickup camper nice w/all the comforts | Bismarck, ND Classifieds
http://s11.photobucket.com/albums/a1...1/SUNP0136.jpg
http://i11.photobucket.com/albums/a1...1/SUNP0220.jpg
have some more pics if somone is interested
In case anyone is interested, I have a 69 bronco thats somewhat in pieces. I have removed the original motor and trans. The new motor and trans are sitting in the back, the new motor is a full roller 351, fresh rebuild, still in plastic and trans is a ZF 5spd. I would really like to keep all these together but if need be I will sell piece by piece. would like $1000 each or $2750 for all
New from the frozen praire.
I'm buyin a 94 F150 that i couldnt pass up for the price.. So i need to sell one of my other rigs. I'm seein if i can sell my 74 E300 dually 4x4..... I have put headers, a 500 cfm carb, and a NP435 trans in it. I would like to get around $2,000 for it, but would let it go for $1,500 to someone here...
its sold
its sold
Selling my wheeler. I'm down sizing. Asking $7000 OBO
Motor is a 351M, bored .030 over, shaved heads, Lunati cam (Adv. Duration 290/300, Lift .536/.562), 4 barrel intake and carb(new), fender well headers, dual points Mallory distributor, 10 qt oil plan, with windage tray. Trans is a C6 auto(a extra stock C6 included) with a shift kit and a 2500 stall converter, with a external filter. Transfer case is a 203/205 doubler with a triple stick shift lever. Rear driveshaft has 1410 ujoints, front has 1330s. The Front axle is a D60 with 5.38 gears riding on a detroit locker that feeds 35 spline axle shafts(inner and outters) Drive flanges instead of lockout hubs and a axle truss. Rear axle is a Ford 10.25 with 5.38s with welded spider gears(a extra axle shaft included) and a thick diamond plate steel diff cover. It has dual two speed electric cooling fans, 100 amp alternator(lifetime warranty), dual batteries, hydraulic assist steering, 44x19.50x15 Pitbull Rocker tires on 32 bolt beadlock wheels, and a 33 gallon gas tank with a electric fuel pump feeding a return style pressure regulator. Its riding on Superflex 4 inch lift coil springs in the front with extended radius arms, rear is stock springs with a shackle flip. Front and rear receiver hitches, front grill guard/push bar. Custom dovetail bed with toolbox. Wheelbase is about 145inches. It is registered/titled as a Class III OHV.
It is a VERY capable off road rig.
