Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 05-31-2011, 03:23 PM
Big_Daddy_O's Avatar
Big_Daddy_O Big_Daddy_O is offline
Garage is empty, add now
Big_Daddy_O is starting off with a positive reputation.
Leveling Kit
Just got my new F250 last week, but when I ordered it I had them put on the snow plow prep. From my understanding they are bigger springs on the front along with the other stuff. It looks to me like the back sits lower than the front so I went and measured it and sure enough the back sits 1 1/2" -1" lower than the front. Do they make a block that you can put under the back leafs to make it level or is their and adjustment for the front springs? I don't plan on running a plow anytime soon. Should I call the dealer and ask them? Thanks
  #2 (permalink)
Old 07-17-2011, 07:17 PM
2011SD's Avatar
2011SD 2011SD is offline
2011SD is starting off with a positive reputation.
I had the same issue with my truck.I installed rear airbags to eliminate rear end squat when I hook up my camper. I just leave 20psi in the bags when I'm not towing and the truck sits dead level.
__________________
2011 F250 FX4 CREW CAB 6.2, LEER 100XL CAP,LINEX BED LINER,FRONT AND REAR HUSKY LINER MUD FLAPS,WEATHER TECH FRONT FLOOR LINERS,55W KC AUX.REVERSE LIGHTS INSIDE THE CAP, LED AUX. REVERSE LIGHTS,HELLA 500FF DRIVING LIGHTS,UPFITTER SWITCHES(added),2010 FACTORY 20" RIMS,FORD REMOTE START(added),295 60 20 NITTO TERRA GRAPPLERS,AIRLIFT LOAD LIFTER 5000 AIRBAGS, BILSTEIN 5100 SHOCKS, BILSTEIN 5100 STEERING STABILIZER, OEM REAR SWAY BAR(added).
  #3 (permalink)
Old 07-18-2011, 07:39 PM
Quote:
Where did you get these airbags at?
I have to ask everyone who has an F250 how many leafs they have in the back? This truck only has 3 and they look the same as an F150 from what I can see. Seems like if you put 500lbs. in the back it squats!
  #4 (permalink)
Old 07-19-2011, 05:32 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
What about throwing a set of F350 blocks under the rear axle?
http://www.ford-trucks.com/forums/10...s-to-f250.html
http://www.ford-trucks.com/forums/10...0-vs-f350.html
http://www.ford-trucks.com/forums/10...2011-f250.html
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #5 (permalink)
Old 07-19-2011, 05:40 AM
2011SD's Avatar
I have 3 leaf springs also. I bought the airbags from streesideauto.com
__________________
  #6 (permalink)
2011SD's Avatar
Sorry I spelled the website wrong its streetsideauto.com
__________________
  #7 (permalink)
Old 07-19-2011, 07:09 PM
Ah thanks for the input guys! Might have to look into different blocks. Just ticks me off that you order a heavy duty truck and its not for the sole sake of the ride.
  #8 (permalink)
Old 07-23-2011, 09:34 AM
blueline38 blueline38 is offline
blueline38 is starting off with a positive reputation.
reverse rake
My truck also has the plow prep and sits at a reverse rake. I spoke with a spring shop and will be putting more leafs in to achieve a 2" lift in the rear plus it will help with sag while towing my camper. Ready lift makes a 4" block which replaces the stock 2" but because I tow they recommended springs. The only issue is the angle of the drive train and warranty!
  #9 (permalink)
Old 08-07-2011, 06:51 PM
Well I took the time yesterday and put in the Ready Lift blocks that I ordered. I must say WOW what a difference they make with adding alittle rake in the truck. It makes it look so much better with the little 17" 245 tires on it. Thanks again guys!
  #10 (permalink)
Old 08-27-2011, 10:34 PM
jfk42367 jfk42367 is offline
jfk42367 is starting off with a positive reputation.
Big Daddy - I have same issue as yours. Please let us know if you are happy with your solution. Where did you get the blocks? Thanks.
  #11 (permalink)
Old 08-28-2011, 06:48 PM
Quote:
Yes I am happy with the way it turned out, it looks much much better without ruining the factory ride which is pretty soft. It will be interesting to see when I haul a ton of coal in the back of it to see how much it sags then! I got mine from Street Side Auto they have fast shipping it only took two days to get. Here is a link:
ReadyLift Part No. 66-2014 - 4.0 in Suspension Block and U-Bolt Kits
Tags
2011, 295, 2956020, at, auto, f250, f350, ford, garage, install, kit, kits, leveled, leveling, pittsburgh, toyo, zone
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
