6.0 no start - Ford Truck Enthusiasts Forums
6.0 no start
Old 05-31-2011, 02:06 PM
revolverivar's Avatar
revolverivar revolverivar is offline
revolverivar is starting off with a positive reputation.
6.0 no start
I have a 2005 F-350 superduty 6.0 that died on me. I have tried to search on this forum and Google but I would like an opinion from you anyway.
This is what happens. It gradually got hard to start but once it starts it runs ok. Several attempts were needed and each time it run only a few seconds. When it finally started it idle is it, no rev possible. As soon as I touch the acceleretor it died. Eventually, as it got warm I could get it moving but I had to rev it hard to get it running smooth.
This only worked a couple of times, now it just starts for a few seconds, no more and its impossible to get running at all.
I am thinking airleak from the HPOP or faulty HPOP.
Codes are P0261-P0282 wich is all injectors. P0611 FICM, P2614 and P2617.
Deleted the EGR last year and a new turbo just after that. I would greatly appreciate your advice guys.
Ivar
Old 05-31-2011, 02:14 PM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
STC fitting failed maybe.
Old 05-31-2011, 02:27 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
With a FICM code (especially w/ codes for all the injectors), isn't the likely culprit the FICM?
Cam and crank sensor codes are a result, not a cause.
Load test each battery individually also.
Old 06-01-2011, 01:05 PM
I took it apart today, down to HPOP and STC. How do I check the parts?
Old 06-01-2011, 01:19 PM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
you will have to do an airleak off test to determine if the HPO system has a leak, but I agree with mark sounds more like an FICM to me. What FICM code were you getting?
Old 06-01-2011, 01:28 PM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
isnt the p0611 code the death code for the ficm?.i think bismic's right again.if i were you id stop and heed his advice.
Old 06-01-2011, 01:46 PM
hubler13f's Avatar
hubler13f hubler13f is offline
hubler13f has a good reputation on FTE.hubler13f has a good reputation on FTE.
I believe that a bad STC fitting would normally give you and P2285 code for the ICP sensor. Basicly the ICP senses the oil pressure built up inside the HPO system feeding the injectors. If the STC fitting was leaking and not allowing the mandatory pressure build up to run the injectors it would normally pop the ICP sensor code P2285.
Sounds like your going through what I went through when my batteries were failing. I agree with Bismic to load test the batteries. Test the batteries before trying to restart again, I believe I have read that continuous cranking and running on low voltage can lead to FICM failure.
Old 06-01-2011, 02:26 PM
bismic's Avatar
wow .
Old 06-01-2011, 03:08 PM
hubler13f's Avatar
Quote:
Originally Posted by bismic View Post
wow .
Did I say something incorrect?
Old 06-01-2011, 03:11 PM
texans's Avatar
I think the "WOW" was the fact that he tore all the way down to where he did without checking the basic stuff. WOW was kind of my thoughts as well!
Old 06-01-2011, 03:16 PM
hubler13f's Avatar
I was thinking "WOW" might have something to do with almost everyone who replied agreed with Mark in some form or fashion.
Old 06-01-2011, 03:36 PM
bismic's Avatar
Quote:
Yup.
Who knows though - I guess it could also have an issue in the HPO system ....
hubler13f - Didn't mean to make you think it was your post - sorry.
Old 06-01-2011, 04:29 PM
hubler13f's Avatar
Yup.
No problems, just thought I might have given some bad info and wanted to correct myself if that was the case.
I don't have any problems admitting I'm wrong, if I knew everything I'd be making the big bucks designing these things and wouldn't be reading this site.
Old 06-01-2011, 04:57 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
wow .
and this.... I just cant top it
Old 06-01-2011, 05:45 PM
2006lariat's Avatar
2006lariat 2006lariat is offline
2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation2006lariat has a superb reputation
On the bright side, his STC fitting will be updated!
Advice - Where to Stop? ericnewmanconst 6.0L Power Stroke Diesel 1 06-21-2016 08:11 PM
PLEASE HELP!!! PCM? huntfish714 6.0L Power Stroke Diesel 8 05-11-2016 02:53 PM
Runs rough cold,no smoke,"sticking" throttle wackercattle 6.0L Power Stroke Diesel 8 02-23-2015 10:00 PM
2005 6.0 with 11xDTC sputter and Black Smoke dukkie 6.0L Power Stroke Diesel 5 02-27-2013 08:27 PM
Loses all power and seems fuel starved after 5 min of running?? schlik83 6.0L Power Stroke Diesel 19 05-19-2011 03:43 PM
Tags
2004, 60, bp, codes, crank, died, f250, ford, nostart, p0261, p0261p0282, p0300, p2285, sensor, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
