2003 Explorer Alarm
The window switches for the power windows will not have an effect on the alarm. The random door ajar message is likely what's causing the alarm to trigger. Unfortunately, you may need to either replace them all or datastream the GEM module to determine which particular switch is the culprit. Often it will be either the driver's door or the rear liftgate/glass as those seem to get the most use.
You could try going around and spraying contact cleaner in each of the latch mechanisms, then open and close the doors several times to work it in to see if you door ajar warnings and random alarm triggers go away, at least temporarily. That will let you know if you're on the right track. Be aware that you'll want to protect the paint from excess contact cleaner as it can discolor/damage the paint.
-Rod
-Rod
It was the liftgate window switch that was replaced, not the power window switch. Also the drivers door one has been replaced also. Are they adjustable?? The dealer check the GEM but as usual it wasn't acting up then and showed no codes. I think I will change all the switches. How hard are they to replace. Dealer said the wanted about $800 to replace the 4 door switches.
Thanks.
Alarm issue
I have same issue the drivers door was bad I put new sensor in and it fixed door ajar problem but alarm keeps going off but only once in while but anyways I don't want to leave it unlocked and if locking it from inside and not using key fob to lock it don't work then idk I did notice that drivers door has two black grounds have been damaged prior and fixed so idk maybe they need to be fixed again lol but any other clues to shays up also I did notice when taking apart lock from door and unplugging some connectors they had some water in them actualy the whole lock looked wet but couldn't tell from all the lube I sprayed but my pops said it looked wet a lil but inside door was dry
MeanGene427
01-14-2024 12:54 PM
APMski
11-02-2014 03:45 PM
