Need help finding factory replacement seat cover for 2005 F250. - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-31-2011, 01:05 PM
scarm scarm is offline
scarm is starting off with a positive reputation.
I have a 2005 F250 supercrew with light grey interior. The drivers seat is ripped from me slidding out of the truck. I called the Ford Garage to order a replacement bottome seat pad - the cost is almost 400.00...
That's crazy - I have searched and searched but cannot find anywhere where I can buy a replacement bottome seat pad cheaper.
Let me know if you have info
Old 05-31-2011, 01:12 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
You won't be able to buy one cheaper and have it match the rest of the seats. You could have custom upholstery done to all the seats, but otherwise it will have to be the OEM part. If you slide on your seats frequently (STOP DOING IT!!), maybe after you spend the money to replace the OEM seat cover, you could buy an aftermarket to go on top to prevent it from happening again.
On a side note, I once saw a trash compactor service crew (they had to crawl in and out of nasty dumpsters), that had a then-new Ford SD truck with thick, clear plastic seat covers to prevent the major staining and stink that would sink into the seats. I would like to get a set of those but I can't find any like that anywhere.
Old 05-31-2011, 02:05 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
Try www.partsguyed.com
I purchased a factory replacement last year from him. Still wasn't real cheap...I think it was around $140 or $180 including shipping. It fit and matched the original fabric perfectly though...
EDIT: My pad/cushion was still good so I didn't need to replace that part. All I replaced was the cover since mine was torn from years of entering and exiting.
Anyone replaced seat covers/cushions? rowekmr 1999 to 2016 Super Duty 1 08-09-2016 07:11 PM
Replacement seat cushions lariat seats 2002exPSD 1999 to 2016 Super Duty 4 01-30-2016 10:47 AM
Seat heater problem woody367 1999 to 2016 Super Duty 0 02-23-2015 07:57 PM
Recovering seat need new padding flipklos 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-16-2015 02:02 AM
Looking for OEM cloth driver's seat bottom cover PaxtonShelby 1999 to 2016 Super Duty 5 09-24-2014 10:05 AM
Tags
2005, 2005 f250 factory seat, cover, covers, driver, f150, f250, factory, ford, original, raptor, replacement, seat, seats, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
