Super Duty 10 Lug hubs setups... - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-31-2011, 01:04 PM
RHM RHM is offline
RHM is starting off with a positive reputation.
Hey there,
New to the site.
I am looking for information regarding super duty 10 lugs setups. I recently purchased a pair of differentials that the previous owner was unsure of their origin.
both diffs are 10 lug, and for a dually.
The rear is a Dana 80, and appears to have 4.63 ratio, huge disc brakes.
The front is a dana 70, Low pinion, drivers side drop, and has 5.13 gears. It also has huge disc brakes on it. The hub is not an adapter of any kind, and it's also 10 lug.
The calipers on the front, and rear axle, appear to be exactly the same.
I purchased the pair of diffs for the front dana 70 with 5.13 gears. I also got a bunch of 10 lug wheels, and a pair of rear leafs packs for the rear axle.... A lot of stuff now resides in my driveway, all just to get the front axle.
The previous owner thought the diffs came from a super duty. I would like to figure out how to put 8 lug standard hubs on this setup.
Anyone have any idea of what these are... ? Is there any value to the rear differential, and the front 10 lug hubs...? As well as all the other stuff I got... i would like sell it all, but if its not worth anything, I'll drop it off for scrap I suppose.
Thanks for any help.
Old 05-31-2011, 01:06 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
The F450 & 550 have 10 lug setups.
Old 05-31-2011, 01:24 PM
RHM RHM is offline
Quote:
I realize that....
But does anyone have any additional information on the diffs I have.
For example, how common is the front Dana 70, how hard it would be to swap to 8 lug hubs... ?
Is there any value to all this other stuff I got? How common is this 10 lug hardware, is it worth anything, or is it all uncommon, and undesirable. ?
Old 05-31-2011, 01:35 PM
jc8825's Avatar
It is just a higher duty (can handle more weight axle). It is used in medium duty trucks like the Chevy Kodiak. I will allow your truck to handle more weight than the 350 axles. Your fuel mileage will drop due to the gear ratios being for moving heavy loads.
I can't attest to the popularity of them. Since they are so heavy duty, it would seem almost too much for true off road enthusiasts.
Old 05-31-2011, 08:52 PM
Gordon-0 Gordon-0 is offline
Gordon-0 is starting off with a positive reputation.
why couldnt you swap gear ratios to what you have now?
you are going to have to change something anyway since you have 4.63 and 5.13 mixed on front and rear
edit:
i dont mean that you swap your current gears in, but if you have 4.55 now then honestly 4.63 isnt that far off, but you can swap the 5.13 to be the same as the 4.63. or you could swap both to be whatever you want
Old 06-02-2011, 06:55 AM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Do you have a project in mind with these axles or are you attempting to sell them?
Old 06-02-2011, 11:31 AM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Depends on the year. My truck has 8 lugs on Dana 80
I wouldn't be surprised if 8 lugs rotors would fit on the axle coming with 10 lugs.
The only way to answer is to try.
Old 06-02-2011, 05:05 PM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
4.63 gears were only offered on 88-97 F Superduty's (F450) that I'm aware of. 99-04 F450's were 8 lug wheels with 4.88's or 5.38's. and 05-up F450's have Dana 110 rears and front coils. If your front axle is a Dana 70, it is probably from a 88-97 4x4 conversion. 99 up F450's had 60 (or super 60) series front ends.
Old 12-01-2012, 02:49 PM
Weareweird69 Weareweird69 is offline
Weareweird69 is starting off with a positive reputation.
Can anyone get in touch the original poster?
64 250 hubs to f100 hubs and brakes Mr. 64 1961 - 1966 F-100 & Larger F-Series Trucks 11 04-01-2014 12:37 AM
1990 10 lug F450 woes! lowzone 1987 - 1996 F150 & Larger F-Series Trucks 18 10-12-2013 12:41 AM
Ford 8.8 Front and Rear axle set BlueOvalBud Offroad & 4x4 1 01-22-2013 08:28 AM
79 F150 4x4 8 lug front conversion??? Donkey punch Brakes, Steering, Suspension, Tires, & Wheels 6 05-28-2010 01:03 PM
Front and rear swaps for 65 2wd F350 RottenRon 1961 - 1966 F-100 & Larger F-Series Trucks 7 10-08-2009 09:20 PM
Tags
10, 1999, 70, axle, dana, duty, earlier, ford, front, hubs, lug, rims, sale, spike, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
