'99 F150 engine swap question - Ford Truck Enthusiasts Forums
Old 05-31-2011, 11:30 AM
petersenj20 petersenj20 is offline
petersenj20 is starting off with a positive reputation.
Hey folks. New guy here.
I bought a 99 F150 from my neighbor for $500 because of a blown motor. I've had trouble finding the replacement 5.4 motor it needs. I have located a 94 Crowne Vic destined for the scrap yard and wondered if the motor is the same. and will be a suitable replacement, before I buy it.
It would be a nice deal to get the junk body and get the truck running. Pay for itself so to speak.
Thanks for the help.
Old 05-31-2011, 12:17 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
what size motor in in the car ? if they are the same then it should work !
Old 05-31-2011, 04:50 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
Why are you having a problem finding a 5.4? There all over the place...lol
Any 99 to 03 F-150 5.4 will work.
Old 05-31-2011, 09:01 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Lots of problems with those old 4.6L's and valve stem seals leaking, not to mention about 70hp less than your 5.4L. It also is not plug and play.
You can find a salvage yard 5.4L for $800-$1500 depending on how many miles you want on it and shipping costs.
Old 05-31-2011, 10:16 PM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
Yeah, you should not have any difficulty finding a 5.4L 2 valve engine.
Old 06-01-2011, 08:28 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
[quote=galaxie641;10408175]Lots of problems with those old 4.6L's and valve stem seals leaking, quote]
The valve stems on the 4.6l are the exact same as the 5.4l. The entire head is the same actually.
And the 5.4l is just as prone to the valve guide leaking. Id know my 02 5.4l that is in my 99 smokes at start up from time to time. Still has good power though. Makes me think that its probably the valve guides leaking.
Old 06-01-2011, 08:29 AM
Put a 5.4l engine in it. Easier and it just makes sense.
Old 06-01-2011, 09:13 PM
DJPRacer58's Avatar
DJPRacer58 DJPRacer58 is offline
DJPRacer58 is starting off with a positive reputation.
and the 94 crown vic has coil packs not cops. a lot of little differences that will make a pia
Old 06-01-2011, 10:13 PM
Thanks for the help guys.
It was supposed to be a 5.4 in the vic. but not. 4.6 as ya'll knew. it had a lein too so i didnt need it.
Old 08-20-2012, 09:52 PM
97 ford jacked up 97 ford jacked up is offline
97 ford jacked up is starting off with a positive reputation.
alright with the 5.4 thing any 5.4 will work
in my case i have a 4.6 in mine with bent valves fixed it once and bent again so changeing motor
i just pulled a 4.6 out of a 2000 crown vic with the same motor the only thing i have to change is timing chain cover,valve covers for truck, oil pan for 4wd, intake for truck. but other than that its easy to change
but a crown vic will not help u out with a 5.4 in the truck now
Old 08-21-2012, 06:48 AM
BFTUFF BFTUFF is offline
BFTUFF is starting off with a positive reputation.
The Crown Vic. is a car motor and is different from the truck motors. Only use a Ford truck motor in a Ford truck.
Old 08-21-2012, 07:08 AM
No the car motor is not different than the truck motor. The Crown Vic 4.6l will drop in place of a truck 4.6l without issue.
The point is that putting a 4.6l engine into a 5.4l truck frame requires some electrical work, and custom tuning. Or a complete engine harness and ECM swap.
Niether of which is fun. Hence just swap a 5.4l in to make it easiest.
Old 08-21-2012, 01:58 PM
Yes it is different, the truck versions have a stouter crank and thrust bearing surfaces that the car version does. I read about it in a "Motor" manual.
Gear ratio? engage 3.8 & 4.2L V6 1 07-04-2015 07:00 PM
99 f150 oil pressure drop kozer 1987 - 1996 F150 & Larger F-Series Trucks 2 01-28-2015 06:56 AM
shorties or long tube exhaust headers no limit 1997 - 2003 F150 34 02-06-2009 09:49 AM
350 chevy motor in my 99 f150 no limit 1997 - 2003 F150 62 01-28-2009 01:00 PM
just a few ?? stock_460 Modular V8 (4.6L, 5.4L) 5 09-23-2008 01:23 PM
Tags
1999, 302, 46, 99, 99f150, blown, engine, f150, fit, ford, motor, parts, replacement, swap, v6, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
