Clutch or bent fork? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-30-2011, 11:21 PM
1468LP 1468LP is offline
1468LP is starting off with a positive reputation.
Hi there I have a '02 F350 with the manual. I've done some searching and not sure what my problem is I was thinking the it was for sure the clutch. The truck is a beast to shift. Trying to get it in low while the truck is running is impossible (shut truck off shifts right in) all other gears are hard also, when driving and shifting I can barely shift also. Once I get it in gear I don't use the clutch as it just doesn't work. I'm thinking clutch as it seems like I have the updated fork it sounds like. With my clutch on the floor if I release it a 1/16" it's engaged. Also if you guys agree it's my clutch how easy are the and what brand and from where? It seems like south bend is the way to go. I pull a 20k+ trailer so need a good clutch. Thanks for reading the long story.
Lamdon
Old 05-31-2011, 09:17 AM
bcaughhorn's Avatar
bcaughhorn bcaughhorn is offline
bcaughhorn is gaining momentum as a positive member of FTE.
sounds like the fork to me. ive pulled one out that was broke and it did the same thing as yours.. but if you got to pull the tranny to change the fork just as well change the clutch too.. as far as the brand of clutch i have no idea.
Old 05-31-2011, 09:42 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Old 05-31-2011, 05:28 PM
429 f-100's Avatar
429 f-100 429 f-100 is offline
429 f-100 has a good reputation on FTE.429 f-100 has a good reputation on FTE.
sounds like hydraulic problems to me . master and slave cyl. these trucks have had issues with them . up dated unit full and pre bled is ford # 2c3z-7c522-ca
Old 05-31-2011, 08:32 PM
Is there a way to tell for sure it's the fork? I already put a pre bled kit in it a while back so that shouldn't be it I will have to look at it more.
Old 05-31-2011, 09:30 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
Here's a couple of trucks with a fork that is not bent.
Old 05-31-2011, 11:18 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
If your fork is bent it would not last long before it will break and you want be able to change gears very easy. Heres a pic of a bent/broke fork.
Thanks for this pic Dan of the old and new fork.
Old 06-01-2011, 09:37 AM
jas88's Avatar
jas88 jas88 is online now
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
On my '02 the fork was not bent, even tho it had the same symptoms as yours. On mine, the problem was the rivets on the clutch plate had failed, so that whenever you pressed the clutch pedal, the pressure plate fingers would run into the now much wider clutch plate and stay locked up. Mine had the improved fork and it was not not bent at all.
Old 06-05-2011, 03:20 PM
I pulled my slave cylinder and it measured 2.5 inches. Would you consider this bent or not?
Old 06-05-2011, 07:08 PM
F350-6's Avatar
2.5" means it's not bent.
Old 06-05-2011, 09:32 PM
Ok thanks hard to tell in the one pic as it looks to be 2 1/4", guess I'll be putting in a southbend
Thank guys
Old 06-25-2012, 10:07 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is online now
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Having same issues now, guys. Went ahead and ordered up a clutch assy, new fork and m/s cylinder set. Wondering, does the tranny need dropped, to remove/install the fork?
Old 06-25-2012, 02:47 PM
mechelement's Avatar
mechelement mechelement is offline
mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.mechelement has a good reputation on FTE.
Quote:
I was wondering the same and read 4 threads, including this one, but couldn't find an answer. I found one thread with a pic showing a measurement from face of slave mount to healthy fork. I believe it was less than 2.5". I guess opting for the manual in Ford doesn't always mean you're in the clear.
1978 F150 with a 3speed Toploader se˝orEddie 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-14-2016 10:53 AM
Clutch fork part number... yellow truck 1967 - 1972 F-100 & Larger F-Series Trucks 14 05-31-2016 07:58 PM
Just About Ready to Set My Truck on Fire. dyingtolive 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 03-30-2012 12:56 AM
I messed up... clutch fork went sideways Shark Racer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 52 08-17-2010 09:35 PM
broken shift fork???? fordtrck302 1987 - 1996 F150 & Larger F-Series Trucks 2 04-05-2008 06:52 PM
Tags
2c3z7c522ca, 600, bent, broken, clutch, early, f250, ford, fork, forks, models, ranchero, reverse, transmission, truck, valair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
