Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-30-2011, 09:29 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Garage is empty, add now
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
How to test icp sensor to make sure they good or bad ?
I can't afford buy parts and pray it work. That why I want test all sensors before buy new sensor.
I was wonder if you can test with ohm meter to see if they good or not?
What cause low voltage 0.02 and HIGHER rpm it 0.04
I keep get P1280
__________________
Sorry for my bad grammar.
Currently drive 2000 f350 7.3L XL 4wd auto. mpg vary 15-17.
1999 F250 5.4L 2wd 5.4L auto with over 246K miles. Got used 5.4L with 100K miles. Need find motivation to install 5.4L.
  #2 (permalink)
Old 05-30-2011, 11:00 PM
tdpower's Avatar
tdpower tdpower is offline
2000 Ford F-250
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
I keep get P1280
What truck are you working on? I don't think your 5.4 would throw that code.....
Here is some more info: ECSD - Injection Control Pressure (ICP) Sensor - 1994-1997 Power Stroke FAQ
  #3 (permalink)
Old 05-30-2011, 11:04 PM
it 2000 F350 7.3L powerstroke diesel
__________________
  #4 (permalink)
Old 05-31-2011, 10:36 AM
machmedic's Avatar
machmedic machmedic is online now
machmedic is starting off with a positive reputation.
Also check the inside of the sensor and the plug for oil. It's a sign its bad. Just changed mine, oil had gotten up into plug and the truck would die if you touched the plug.
__________________
2003 F-350 Lariat CC 4x4 7.3L Auto 148K miles
CCV mod, 6637 Filter, guages, WW, 4" MBRP.
1965 Mustang 289-2V 3 speed
1997 Taurus 3.0L OHV
Tags
73, 73l, bad, check, f250, ford, icp, ipc, low, powerstroke, sencer, sensor, test, testing, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
