A/C Problem
A/C Problem
Ok guys here is what I have e99 F-250. Freon is fully charged, at idle it only cools to about 75 degrees, and driving it cools to 50 degrees. Outside air temp is 93 degrees. Fan clutch works, high and low side pressures are good. Condensor and evaporator core are both clean. Any idea what is going on.
You might want to consider installing a valve in the heater hose to stop flow of hot water into the cab, in addition to setting the clutch air gap.
Texas Mad Man
01-11-2009 11:00 AM
reamer
07-31-2004 03:27 PM
