Power Steering Box/Repair or Replace - Ford Truck Enthusiasts Forums
Old 05-30-2011, 12:14 PM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
I thought I would check to see if any members have rebuilt the 73-76 power steering box; if so, does it require special tools and is it involved. Just rebuilt the steering column when I noticed the minor leak in the power steering box is getting worse. Kinda between rock and hard place, need the truck and faced with the dilemma whether to bite the bullet and pay for a replacement, figure the removal and installation should only take a few hours; or attempt to rebuild where the time it would take to get the truck on the road is unknown. I checked the online inventory with the local 'Pic n Pulls' and they don't have any 70's Ford pickups on the lot at this time. Anyhow, suggestions, input appreciated!
Old 05-30-2011, 05:04 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Upper end is a little more tricky, but if it's the lower end, just put a seal kit in it.
It does take some big wrenches and a fork to get the pittman arm off, but not too big of a job.
John
Old 05-30-2011, 05:41 PM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
i think you'll need a pair of snap-ring pliers. i rebuilt one several times...never could get it to stop leaking. ended up using it as a core for a rebuilt unit.
Old 05-30-2011, 05:51 PM
John, thank you for the info, affraid if I were to open it up may find 1 of the components projecting to neighbors house. Appears majority of the fluid is coming from the bottom end, hopefully able to tell more once it's pulled. I do have a front end kit so removing the pitman arm should not be a problem. Went to Napa online inventory and they have a bottom seal kit that runs around $20, looks like it only consist of 3 components so I should be able to do that much. I will not be attempting the full rebuild kit, too many parts to the kit to keep track of. Again thank you!!.
Old 05-30-2011, 08:20 PM
Quote:
Figure once the box is removed I'll have better sense of what needs to be done, if there's any question whether the kit will solve the problem I agree, the darn box is expensive enough as it is don't need to kick in an additional $20 bucks. Thanks for input!!.
Old 05-31-2011, 07:26 AM
jowilker's Avatar
Dave it's been a while, seems there is a double seal down there, and maybe 3 pieces total to replace. Once you get in it you have past the big hurtles.
guluk
John
Old 05-31-2011, 09:52 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by daveengelson View Post
Appears majority of the fluid is coming from the bottom end.
Uh huh, and within a year or so, the puppy will be leaking from the same location again, you wanna know why?
All the Ford integral P/S gearboxes have a built in flaw, no bearings on the sector shaft. It doesn't take too long for the seal to become oblong, the housing takes a beating too.
Since there are no internal parts for the 1960/70's gearboxes available any longer except for what makes up the two seals kits (input & sector shafts), the so-called autoparts store rebuilt gearboxes are really re-sealed gearboxes.
redheadsteeringgears.com (located in Seattle) takes the housing, machines it, installs the needle bearings that Ford left out...on purpose, so they could sell a gazillion seal kits.
D7AZ-3E501-B (replaced D3AZ-3E501-A & C5AZ-3C538-A) .. Sector Shaft Seal Kit / Available from Ford.
MSRP: $24.18 // FTE sponsor PARTSGUYED.COM price: $17.41.
F3AZ-3E502-A (replaced D7AZ-3E502-A, D3AZ-3E502-A & C5AZ-3C538-A) .. Input Shaft Seal Kit / Available from Ford.
MSRP: $24.02 // PARTSGUYED.COM price: $17.29.
Applications: ALL 1965/2002 Passenger Car/Truck/Bronco/Econoline and et cetera Ford Integral P/S Gearboxes.
Old 05-31-2011, 11:33 AM
Bill, thanks for the resource, I am kinda slow, if understand correctly the kits mentioned are pretty much a temporary fix, perhaps 2-3 yrs.; further, majority of the reman's use the same/simular kits and I can expect the same results. Checked w/ local Napa auto and then called 'redheadsteering', for approx. $50, plus s/h more, they have a replacement, and likely a better quality rebuilt gear box.
Old 05-31-2011, 01:19 PM
OldHarley's Avatar
OldHarley OldHarley is offline
OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.OldHarley has a good reputation on FTE.
I would think that $50. additional would be a absolutely great deal.
If, I were going to buy a new box, and planned to keep the truck for any length of time, I would spend the extra dough!
Problem always is, that the cost of a $500. gearbox gets compared to the cost of the much-needed upholstery, paint or bodywork, or a super-duper transmission and folks would rather spend the $500. on one of the above and $20. on a seal kit.
Old 05-31-2011, 03:26 PM
jowilker's Avatar
I must have gotten a bad seal kit, because mine has holding the oil for 10-12 years now. dadnabit
John
Old 05-31-2011, 03:55 PM
Agree, but I failed to estimate cost of shipping, follow up telephone call and got a quote of $80 both ways. Been doing some 'cyber shopping' and came across company that offers lifetime guarantee, only problem is they don't provide a contact telephone # or address, I did email them. Now faced w/ dilemma, an additional $130 may be the deciding factor. Guess another option is to check local 'pic n pulls' for next few days until a truck surfaces then run down and see if it has the correct power steering box; they charge $50, plus a return charge; bout 100 mi's round trip, at $4.50/gal a couple unsuccessful trips then the cost for the shipping may be worth it. Then again, for the #20-30$ for the bottom end kit perhaps like John may get luck and get few yrs. O'well, gives me something to ponder!
Old 05-31-2011, 04:39 PM
OldHarley's Avatar
Hmmm..No address or telephone number, but a lifetime guarantee...
Come to think of it, dave, I gotta guy, ...a Nigerian businessman, as I recall, ...he has 50 million in gold, but can't get it out of his country. If you want the details, I can send 'em to you!!
Old 05-31-2011, 05:56 PM
Greg, I get the same emails unfortunately hav't had the time to send him any money.
Surprisingly REMsteering returned my email and noted the info is on their webpage; although I did find the tele# I still can't find the address on their webpage, nor did they include it in their email. What's more interesting, I called and was informed they are located in the Palm Springs areak, yep here in the great state (?) of Ca., but still did not give me an address. Sounds like 'here today and gone tomorrow, anyhow, still pondering.
Old 06-01-2011, 01:21 AM
Quote:
Originally Posted by jowilker View Post
I must have gotten a bad seal kit, because mine has holding the oil for 10-12 years now. dadnabit.
(sigh) All I can say is...you've lucked out. Integral P/S was introduced in 1965 Galaxie/LTD.
Thru 1972, the only seal kit was a master, then Ford replaced it with individual input/sector seal kits.
I prolly passed out 10,000 of these puppies in 35 years, you wanna know why?
Because without sector shaft bearings, the sector shaft seal only lasts sooo long, then the little darlin' starts leaking again.
If the boxes didn't have this built in flaw, why are there companies machining the cases to install the bearings?
Because...unlike you, 10's of 1000's of peeps haven't been as fortunate.
Old 06-04-2011, 06:51 PM
Pulled the p/S box and appeared fluid had been leaking from every oriice for quite some time. Purchased a Napa auto reman w/ lifetime warrantee, surpised to find price varied between various Napa stores. Anyhow, just returned from test run and wow, truck has never steered w/ this much ease since installing the donor box. Thanks for the input.
86 f250 steering box nick c Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 01-28-2016 02:29 PM
'76 f100 Steering gear box leaking! Harbormaster1976 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-23-2014 03:42 AM
Power steering leak & loose steering gudor 1973 - 1979 F-100 & Larger F-Series Trucks 10 06-16-2014 03:26 PM
I think I will be replacing the steering box... Joco 1967 - 1972 F-100 & Larger F-Series Trucks 10 06-13-2014 03:04 PM
Rebuild kit for Toyo Steering Gear box teardropty 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 07-17-2012 02:18 PM
Tags
1999, 2003, 2004, box, change, diesel, f150, f250, f350, ford, power, powersteering, repair, replace, replacing, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
