7.3 OIL PAN - Ford Truck Enthusiasts Forums
7.3 OIL PAN
Old 05-30-2011, 12:00 PM
fancyvern fancyvern is offline
fancyvern is starting off with a positive reputation.
7.3 OIL PAN
2002 F-350 4X4 AUTO TRANS. CAN YOU REPLACE THE OIL PAN WITHOUT REMOVING THE ENGINE? THANKS
Old 05-30-2011, 01:06 PM
rattleNsmoke's Avatar
rattleNsmoke rattleNsmoke is offline
rattleNsmoke is gaining momentum as a positive member of FTE.
I don't think so. Plus the engine block should be upside down when letting the gasket maker cure else you will get leaks. At least that's what I have been told by several diesel techs. If yours is porous like my '94 plow trucks is, try JB Weld after draining the oil for a few days. The stuff works. Good luck.
Old 05-30-2011, 10:32 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old 05-30-2011, 10:53 PM
ToMang07's Avatar
ToMang07 ToMang07 is offline
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
The only way to do it without removing the engine is to cut out the crossmembers, install the new pan, and weld the crossmeembers back in.
Really not a good plan.
I came across a thread where the guy claimed he pulled the tranny, and basically disconnected the engine and tilted it enough to put a new pan in...
But really, it needs to be pulled.
My pan is getting bad, too. I am going to sand it down good and paint it this month.... hopefully that will hold it for a while.
Old 05-30-2011, 11:42 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Mine wasn't bad, just some patchy rust bubbling under the paint and after muiltable paintings I sanded it down real good and applied some Rust Bullet, 2 or 3 coats and you'll be good. Whatever rust is still on there the R-B compounds dehydrates the moisture in the rust and metal and seals it. 10 year waranty to boot. Check them out, their a sponsor above..
Old 05-30-2011, 11:48 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
My pan is still in good condition. Is there anything I can/should do to make it last? Maybe paint it with rust-proof paint?
Old 05-31-2011, 07:15 AM
Rose Clifford's Avatar
Rose Clifford Rose Clifford is offline
Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.
there's a guy in MA that epoxy's a fiberglass cover on it
YouTube - ‪7.3 Ford Rusted Oil Pan Repair Kit (1of 2)‬‏
Old 05-31-2011, 08:15 AM
nlemerise's Avatar
nlemerise nlemerise is offline
nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.nlemerise has a spectacular reputation.
Quote:
The best thing is to live in an area where rust is not an issue ...next best thing is to follow big poppa's suggestion on using Rust Bullet.
Old 05-31-2011, 08:30 AM
ltl_jrw's Avatar
ltl_jrw ltl_jrw is offline
ltl_jrw is starting off with a positive reputation.
That is a great pan fix.
Old 05-31-2011, 10:15 AM
ToMang07's Avatar
I would think putting a "cover" over the oil pan would be like putting a plastic bedliner in a rusty bed....
just sayin...
Old 05-31-2011, 10:23 AM
clem1226's Avatar
clem1226 clem1226 is online now
clem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to beholdclem1226 is a splendid one to behold
just sayin...
if you used 10 gallons of epoxy after spending 2 days cleaning all the rust off the bed it would be pretty much the same thing.
I see no issue with repairing a pan in this manner. The pan rusts out because it was drawn thin in the stamping process. If I had a soft spot in the bed because there was thin steel used I wouldn't hesitate to slather it up with fiberglass and call it a day, I doubt I would replace it with another bed that has the same defect from the factory.
Old 05-31-2011, 10:40 AM
Cheaping out on the bed is one thing, letting rust flakes get into your oil is another...I'm all for a quick cheap fix as long as it doesn't compromise anything. I am skeptical about the cover for the oil pan, I think if its done early enough its all well and good, but if you do it when your oil pan is falling apart you might be asking for trouble.
Old 05-31-2011, 11:06 AM
clem1226's Avatar
cheaping out? if the design was faulty ( as is the oil pan) from the get go where is the cheaping out? Because you fixed it better than stock for less than stock replacement does than make it less desirable or more?
as to the rust flakes in the oil....they rust from the outside in, I have yet to pull the pan off any running engine and see rust underneath the oil IN the pan.
Old 05-31-2011, 11:43 AM
Hence why I said its all good if its done early enough.
Cheaping out meaning cheaper than getting a new pan and POR15'ing it
Sorry for not explaining myself thoroughly enough
Old 05-31-2011, 12:33 PM
clem1226's Avatar
I would agree with that, if it is absolute swiss cheese with no good metal left to bond too a new pan is a must, but most of the time there are a one or two small spots that are just starting to weep.
ya know the one thing that would worry me about repairing my pan with the diaper would be engine oil temps. A lot of cooling occurs at the pan. I would make sure I had an EOT gauge.
How hard is it to tighten the oil pan on 4x4? Phil Woolfson 1987 - 1996 F150 & Larger F-Series Trucks 7 05-20-2014 08:36 PM
oil pan removal? 79sparky Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 11-12-2013 11:03 PM
Anyone converted their 65-66 to a rear sump oil pan? dsrtjeeper 1961 - 1966 F-100 & Larger F-Series Trucks 15 11-18-2011 09:40 AM
1998 F150 OIL PAN LEAK robjs111 1997 - 2003 F150 5 04-01-2011 09:19 PM
decode oil pan numbers smoove_d 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 0 10-31-2005 08:34 PM
Tags
2002, 73, diesel, f250, fiberglass, fix, ford, leak, liner, michigan, motor, oil, pan, pulling, sd, west
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
