53 Flathead, radiator hose pipe - Ford Truck Enthusiasts Forums
Old 05-30-2011, 04:00 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
Does anyone know where I can get a new set of radiator hose pipes for a 53 f100? Mine are full of rust pits and after sand blasting, pin-holes.
I wonder if an exhaust shop can bend 1 1/4" pipe, and how well that would hold up?
I have found several in stainless or chrome, but I want the original painted pipes. Besides, the pipes they sell are for 48-53, and they don't look right. The 53s were different.
Thanks.
Old 05-30-2011, 05:46 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
TAAC-8290-A .. Pipe-Cylinder Head to Radiator 1 1/4" diameter / Obsolete / 1953 F100/600 239.
ANTIQUE AUTO SUPPLY in Arlington TX has 6 = 817-275-2381.
Old 12-05-2012, 04:22 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford Fat Fendered Ford is offline
Fat Fendered Ford is starting off with a positive reputation.
I know this is digging up an old thread but I'm running into the same problem as the original poster who was trying to locate a set of these pipes. Anybody know of a source for these? I called Antique Auto Supply but they are now out. What does a current parts search return? I might be able to make my current set of pipes work but they are starting to deteriorate. I found an eBay auction where someone is selling a repro set but they look a little cheesy to me: 1953-Ford-Flathead-V8-Pickup-Truck-Radiator-Hose-Tubes-Steel-New-Hot-Rod-Restore
Old 12-05-2012, 04:49 PM
yamagrant's Avatar
yamagrant yamagrant is offline
yamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputationyamagrant has a superb reputation
Thanks.
I had made some custom pipe for a rad hose years ago when I worked for a muffler shop. They served me very well. We also recently had a muffler shop make some for the lower rad pipe on our Petrbilt's with CAT engine's and they also worked.
Old 12-05-2012, 05:15 PM
5 Star's Avatar
5 Star 5 Star is offline
5 Star is starting off with a positive reputation.
53 Rad Pipe
Rad Pipe, for 53 yes you would be better off getting your local Muffler Shop bend a pair for you, better Metal, and they don't come from china.
Old 12-05-2012, 08:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Quote:
Originally Posted by Fat Fendered Ford View Post
.... I found an eBay auction where someone is selling a repro set but they look a little cheesy to me: 1953-Ford-Flathead-V8-Pickup-Truck-Radiator-Hose-Tubes-Steel-New-Hot-Rod-Restore
"Make sure you notice the welds on the ends"
How could you miss them?!? Looks like a blind man with a battery and coat hanger made those welds. That's just unbelievable.
You may be as well off for the time being with the flex hoses sold at NAPA and such.
Old 12-05-2012, 08:51 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Kevin,
I thought you have a 215 in your 53, unless this is for a different build?
Old 12-05-2012, 09:43 PM
needhelp49 needhelp49 is offline
needhelp49 is gaining momentum as a positive member of FTE.
Old 12-05-2012, 09:44 PM
it's on page 93 not sure why 92 came up
Old 12-05-2012, 10:14 PM
needhelp49, Yup, that's them. It's a new addition to their catalog. They didn't have them when I was looking for them.
Edit: I stand corrected. That's the same thing they had when I was looking before.
They are not exactly the shape of the 1953. On the '53 the engine sits a little higher compared to the radiator, so the pipe is not as tall. It looks like theirs has 2 45 degree angles, the '53s do not. See the second picture and the PDF drawing below.
Old 12-05-2012, 10:19 PM
ALBUQ F-1's Avatar
postin' fool
Couldn't you use 48-52 pipes with longer rubber hoses as needed to make up the difference?
Old 12-06-2012, 02:56 AM
Mervy49's Avatar
Mervy49 Mervy49 is offline
Mervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to allMervy49 is a name known to all
The 49's have just a little different shaped bends I think.
Sorry about the crappy picture
Old 12-06-2012, 02:41 PM
Quote:
Originally Posted by 51PanelMan View Post
Kevin,
This summer I finally came to the realization that I needed to throttle my ambitions back a little. I was trying to build two trucks at once - a show truck and a daily driver. Wasn't really getting anywhere with either one. So, I decided to focus on something in between. I sold all my extra parts and kept the best to build one truck. I wanted to go with the flathead so I pulled the 215. I haven't decided what to do with it yet. It runs great and I put a lot of time and money into the rebuild. Probably not a lot of demand for an engine that was only produced two years. Or maybe that makes it rare...
Anyway, that's why I'm pursuing the coolant pipes. I could probably get by with what the ones I have but I'd feel a lot better with something new.
OE heater hoses mrollings53 1987 - 1996 F150 & Larger F-Series Trucks 3 11-08-2016 10:38 PM
'53 F100 Radiator Hose jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-16-2016 11:45 AM
upper radiator pipes hardy53 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 10-07-2015 08:29 PM
Radiator Hoses 6 cylinder 52/53 F1 52 USCG Panel 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 01-13-2015 10:36 PM
Coolant pipe from radiator to throttle body Island Time 1987 - 1996 F150 & Larger F-Series Trucks 5 10-27-2014 11:17 AM
Tags
239, 53, f1, f100, flat, flathead, ford, head, hose, kit, pipe, radiator, truck, tubes, upper, v8, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
