toploader 4sp into a 77 f250
Old 05-29-2011, 10:14 PM
Bigjl's Avatar
Bigjl
Bigjl is offline
I was wonderin if anyone has swapped a toploader 4sp in place of a truck 4sp in a high boy.
Old 05-29-2011, 10:42 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Tailshaft is probably too long to accomadate the short shaft to the transfer.
Josh
Old 05-30-2011, 08:41 AM
jmm's Avatar
jmm
jmm is offline
im confused because the highboy np435 four speed is a toploader? not sure what your switching it from.
Old 05-30-2011, 09:25 AM
Bullitt390's Avatar
Bullitt390
The "Toploader" is the main car racing transmission known for it's strength and durability despite it's size.
True the NP435, T18/19 are "toploaders", but they are not THE Toploader.
Josh
Old 05-30-2011, 09:21 PM
Bigjl's Avatar
Bigjl
Bigjl is offline
im taking it from a 4sp fairlane, my truck has a divorced t case and it will fit just wonderin if anyone has done it. tired of the long slow shifting truck 4sp
Old 05-31-2011, 06:02 AM
jim collins's Avatar
jim collins
jim collins is offline
I done it in a 2 wheel drive F-100. Moved the trans mount to a different hole in the frame and got a different drive shaft. Overall pretty easy job.
Old 05-31-2011, 06:52 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Josh
Exactly. The common term "toploader transmission" is a side shifter with linkage, where the NP435 etc are top, direct shifted. All the internals are loaded thru the top cover.
Old 05-31-2011, 11:03 AM
Bullitt390's Avatar
Bullitt390
Throwing the Toploader in a 2wd is cakewalk compared to adapting it to a transfer case.
David Kee sells the adapters.
Josh
Old 05-31-2011, 06:01 PM
jim collins
Josh
I said MINE was an easy job.His would take a little more work. Besides i assumed he would expect his would be more work.
Old 05-31-2011, 09:15 PM
Bullitt390's Avatar
Bullitt390
Next time I'll turn on my mind reading powers as your original post did not portray what you are now trying to say.
Josh
Old 06-01-2011, 07:02 AM
jim collins
Josh
Hey man,what is your problem? You have this thing about wanting to correct or question anything i post in the threads you post in. I don't see any reason to put everything in detail for somebody.If they can't figure some of it out on their own ,then maybe they should not be trying it. You do it your way and i will do it my way.I will give them ideas but i am not going to do it for them unless they bring it to my shop so i can get paid for it. If you want to list everything out for them in a numbered order,go ahead, that's not my way of doing it. You have been the only person that has questioned my ideas on here,if you don't like or agree with them ,then just keep it to your self . I agree with most of what you put on here ,but the things i don't agree with,i keep it to myself. Your last comment was very immature and uncalled for. I will not be explaining myself to you anymore . I'm only doing it this time to show you i am willing to let the past go,but if you can't then i will ignore you from now on. I have tried to get along with you ,so what is your problem ? Anymore discussions need to be someplace other than the post forum and i do not plan to explain why i put this one here. I think you can figure that out with out any mind reading powers.
Old 06-03-2011, 12:55 AM
Bigjl's Avatar
Bigjl
Bigjl is offline
i have a divorced t case so shouldnt be 2 hard i think
PRUSue
08-31-2016 11:34 PM
tdawglp
WTB - Parts & other
11-04-2015 05:42 AM
78ClimaxVFT
02-20-2015 02:02 PM
spectruck59
02-11-2015 04:33 PM
markthompson999
04-22-2012 04:32 PM
Quick Reply: toploader 4sp into a 77 f250
