I have a 1984 ford f250 with a 460 gas engine. The blinker fuse keeps blowing and Im problem and what have you found to be the problem or possible proble
Seriously, trailer wiring is the number 1 cause. Followed by a bare wire at one of the signal light sockets.
If the brake light fuse has not given any issue, then it could be up front. Does it tend to do it when the right of left signal is used? Or is it random?
its just been sporadic and only been happening since around Christmas. I was thinking that it went with my flasher. but it just happened again today. im ganna bet on the trailer wire though. guys that owned it before me wernt to bright
