Power window fuse - Ford Truck Enthusiasts Forums
Power window fuse
Old 05-29-2011, 05:58 PM
Headviking's Avatar
Headviking Headviking is offline
Headviking is gaining momentum as a positive member of FTE.Headviking is gaining momentum as a positive member of FTE.
Power window fuse
I have an electrical problem with my power windows fuse. If anyone knows this fuse/relay (silver) under the drivers side knee bolster keeps blowing/resetting itself. I mean the fuse gets really hot and when I remove the fuse and let it cool down and I put it back the windows will work for a couple of minutes and the again will get hot and blow. I have never had any electrical problem before this.
Anyone ever have a short or any power window fuse blowing problem and found a fix?
Old 05-29-2011, 07:30 PM
Headviking's Avatar
Additional info. I reinserted the fuse with the drivers door open, windows all worked fine. I was touching the fuse while the ignition was turned on .... fuse did not warm up, windows all worked fine. I put my hand on the wire harness that leads from the door to the pillars, grabbed it hand twisted it back and forth, up and downnnnnnnnn....thats when I heard a spark (I think). I turned the ignition off right away and pulled the fuse. I unplugged the harness from the pillar and looked over all the pins..(they all looked good and firm). Replugged it back in and all fine. Again I pulled it back and forth ... up and down. Still fuse ok and did not heat up. Need to find out what and how to fix it properly so it doesn't happen while it's raining and I loose the ability to close the windows.
Power window motor problem wrhatt 1978 - 1996 Big Bronco 5 06-28-2016 03:15 PM
2005 f250 blowing fuse #41 sailan 1999 to 2016 Super Duty 4 04-14-2011 01:22 AM
Interior lights and windows problems... Keith73 Excursion - King of SUVs 13 03-29-2008 01:47 PM
2002 F150 Supercrew fuse blowing problem 2002F150 Electrical Systems/Wiring 3 05-24-2004 03:14 PM
fuse keeps blowing djgsolo Electrical Systems/Wiring 14 01-02-2004 11:13 PM
Tags
2005, back, blowing, e150, escape, f150, f250, f350, ford, fuse, fuses, power, ranger, relay, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
