IWE actuator replacement - Ford Truck Enthusiasts Forums
Old 05-29-2011, 04:52 PM
friscofordguy friscofordguy is offline
friscofordguy is starting off with a positive reputation.
This is probably one of the easier suspension/drive-line fixes I've ever completed. The frustrating thing is that I tore up the upper ball joint boots separating the bj from the knuckle with the bj separator fork. Thankfully rockauto.com has the moog control arm w/ the replaceable bj for about relatively short money. I'll replace the control arms next weekend one they arrive.
So, the tip I'll give for the actuator replacement is that you ought to seriously think about having the control arms on hand to replace as well b/c you'll probably tear up the bj boot w/ this replacement.
Do any of you have a technique to get the bj and knuckle separated w/o tearing up the bj boot?
The final verdict is that the OE actuators were both junk. Seems like the internal spring must have been broken and/or the whole inside was just gummed up. The new units compressed nicely and held with the vacuum cap in place. Then when I took the caps off they would extend correctly. Found an unfinished subdivision to check my work out in. Everything works nicely again and hopefully I'll gain a couple MPGs now.
Old 11-16-2011, 03:51 AM
Kmsalvadore Kmsalvadore is offline
Kmsalvadore is starting off with a positive reputation.
I have to replace my IWE actuator any suggestions on how to replace without tearing anything else up? Do you have a manual that you used if so any suggestions?
Thank you
Old 11-16-2011, 07:09 AM
60DRB's Avatar
60DRB 60DRB is offline
60DRB is gaining momentum as a positive member of FTE.60DRB is gaining momentum as a positive member of FTE.
I don't think I messed with the upper joint when I did mine. The repairs are a lot easier than a lot of people realize. One of mine was broken like you describe.
Don't waste your money on a Haynes manual for 4x4 repairs. It tells you virtually nothing about repairing 4WD, regardless of what the cover may say.
Here's what I used;
http://www.f150online.com/forums/2004-2008-f-150/360269-iwes-removal-replacing.html
Has pictures and a list of tools needed.
Old 11-16-2011, 07:27 AM
xjcamaro89's Avatar
xjcamaro89 xjcamaro89 is offline
xjcamaro89 is gaining momentum as a positive member of FTE.
I have a trick for upper ball joints on these trucks. Take a small like 2 lb sledge and tap heavily on the top end of the spindle where the ball joint goes through, its cast iron so your not going to hurt it, dont hit the upper control arm though. Usually within a couple hard knocks the thing pops out. Thats how i did mine, had them apart several times for the IWE and struts and did it like that every time.
Old 11-16-2011, 09:11 AM
Thank you for the help
Great BJ's x-plan pricing Bigdon68 2017 Super Duty 12 10-18-2016 08:24 PM
Dana 50 TTB parts exranger06 Ford Truck Parts for Sale 7 05-19-2015 09:07 AM
Remove steering nuckle without damaging ball joints? outdoorfan 1987 - 1996 F150 & Larger F-Series Trucks 24 12-19-2011 12:42 AM
Fixed 99 XP loose steering orleec Expedition & Navigator 0 12-31-2010 08:43 PM
Tags
05, 150, 1997, accuator, actuator, actuators, buy, change, f150, ford, iwe, location, replace, sale, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
