air bags or overloads?
got my hands on a sweet 9.5 foot camper, my truck is a 97 f250 reg cab HD powerstroke. it saggs pretty bad with it in the back, i dunno maby my springs r worn out but you would think the HD could handle it. so i got some airbags that i can get for cheap, looks simple enough to install, what kind of air pressure is normally run in that type of application?
You guys think overloads would be better, because i might be able to get some of them for cheap as well.
Are we talking in bed camper? Air bags are great for leveling out the load, but they tend to increase the roll a bit. Not a lot, but a little. Overloads are good but if your springs are worn they may not be enough.
Both overloads and airbags would be ideal. You can stick a spacer between the overload and stop to give you added sway control and have the bags do most of the load leveling.
I do have the one ton dually that oldbird is talking about. I have the bags and I have not had the "roll" that some talk about. I have loaded my truck to the max several times. From pallets of concrete, yes 2 full skids with 60# bags. Put an air compressor on your truck. I didn't for the first couple years. What a PITA! It's nice to load and air up or down. I have the Firestone bags and haven't had any problems to date.
It's side to side and you'll only notice it after first installing the airbags. You quickly get used to it and I don't even notice it anymore. Squatting down on overloads does provide more stability, but I got to the point with my old springs that I was hitting the overloads with only a few hundred pounds. Airbags quickly fixed my droopy rear end, but I noticed the roll when I loaded it down and didn't touch the overloads.
If your springs were good then you wouldn't need overloads or airbags. Although overloads are nice to help stabilize some of the body roll out. Sway bars are almost a must. My slide in weighs right at 3800 pounds fully loaded and the factory overloads are about an inch from contacting the pads with it. They just barely touch when I hook our bumper pull horse trailer on too. That's 16000 pounds on it's axles with three horses. I'd say get your springs rearched back to factory specs and install new rubber bushings and new shackles.
Like Talyn states you can have a proportioning valve or have them air up separately. I have neither and have not had the problem. Proportioning valves are cheap insurance if you put the bags on.
Thanks Chris, I get a lot of front to rear 'slap in the ***' I call it. Its where you go through up and down dips and the 5er will slap me hard. I just white knuckle it when I feel it coming. There was a thread awhile back about a guy with a cracked frame near the rear shocks and every time I get nailed with my 'slap in the ***' I think about that thread. One of these days I really need to craw under there and look around.
Have you tried airing down any Glenn? I've been surprised how well 60 psi handles many loads and rarely go above that anymore.
And for the record, my bags are plumbed separate so there's no air moving back and forth between bags causing the roll. The problem is your balancing more of the load on a single point (the bag). Grab a 3' long piece of pipe and carry it around in front of you in one hand (air bag) holding it level. Then try again holding it with 2 hands spread out (front & rear of the leaf spring). Which is easier to keep the pipe level?
