1955 F250 Brakes
1955 F250 Brakes
I have a 1955 F250, I was wondering if I could use the 12 1/8" X 2" brake drum and shoes instead of the 12" X 2" that originally came with the truck? I have a 1968 DANA rear which has the 12 1/8" X 2" set up, can't seem to locate the 12' X 2" front drums. Did the backing plate change between the two? I need 2- rear brake drums 12 1/8" X 2" and 2- front either the 12" X 2" or 12 1/8" X 2" if they will work.
12" x 2" brakes used thru 1955. 1956 was the first year for 12 1/8" x 2" brakes.
2) 1D-2211-B .. Right/Left Rear Backing Plate / 1951/52 F2/F3 / 1953/56 F250.
2) TBAA-1126-A .. Rear Brake Drum-Use w/12" x 2" brakes / 1951/52 F2/F3 / 1953/55 F250 / Obsolete
No Ford Dealer or obsolete parts vendor has any.
2) B6D-1126-A .. Rear Brake Drum-Use w/12 1/8" x 2" brakes / Obsolete
Applications: 1956/58 F250 / 1959/66 F250 2WD/4WD
COLLECTORS AUTO SUPPLY in Oroville WA has ONE = 800-414-4462.
NOS PARTS SOURCE in Olathe KS has ONE = 913-220-5746.
I don't know if these drums will fit, I'm just listing the part number/applications.
Worked out great, only problem is my front wheels will not fit because of the 1/8" difference, not a big problem, they were 15" wheels anyway, plan on getting 16" some day. I do not have the truck on the road, but I'm sure they will work fine, I replaced everything.
So I was able to find 56 drums via Napa. P/N is 440-1025 at $98 for the pair. Only minor differences that I don't see impacting the application. I'm wondering if the original drums had already been swapped out in the past. I'll try and post a pic later of the side by side. I still have some clean up before I am ready to reassemble. Internet shopping is great but it was nice being able to compare side by side before dropping the cash.
1953 F3 Replacement Brake Drums
So I see a couple years has passed since this thread was updated.
Did you try the >1956 12 1/8" x 2" x 8 lug x 6.5" drums on your OEM backing plates with the OEM hubs?....and did everything bolt up without any problems or mods??
I'm hoping this is a good news story and response as the original OEM drums are no where to be found on this big ball we call earth but I am able to suss out 12 1/8" x 2" drums.
Did you do both front and rear?
