Glow Plug Controller, Glow Plug Relay - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-29-2011, 12:56 AM
Krazymaan Krazymaan is offline
Krazymaan is gaining momentum as a positive member of FTE.
So on my 2001 E 350 Superduty Diesel. I see online and everywhere else that I don't have a Glow Plug Relay. I supposedly have a Glow Plug Controller. Thats the electronic aluminum box with two connectors going into it. I can't find that thing on my Van for nothing. What I do see is two solenoids on the front passenger side right where the Truck solenoids are suppose to be. So I am scratching my head wondering why I would have this setup instead of what I am supposedly suppose to have. Obviously it would be the solenoid in the rear of the front one. The van smokes like a steam train when cold, only will start with a tiny tiny shot of starting fluid and If I do have the traditional mechanical Glow Plug Relay. It does not click when i turn the key forward.
Now for the Ford guys that know everything. My E350 Superduty is actually one of the Incomplete Chassis carrying a 14' cube box on the back with duallies. Maybe thats the reason for the other solenoid instead of the one claiming to be for my van. Anybody know what I am talking about and can clairify this?
Old 05-29-2011, 02:21 AM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
I cannot clarify if you do or do not have a GPCM (GlowPlug Control Module), or as you called it Glow Plug Controller.
If you do it will look like this and is in the center of your motor just to the left, near your fuel filter.
Old 05-29-2011, 09:16 AM
new2diesel new2diesel is offline
new2diesel is starting off with a positive reputation.
To check the relay (if that's what you have) is real easy. Put a volt meter
on both large dia. posts, 1 will have 12+ volts the other won't, turn on the
key and check if you have voltage at the one that didn't have any before.
If you have voltage now then replace ALL glow plugs instead of trying to
find bad ones. If you don't have voltage, replace gpr
Old 05-29-2011, 06:25 PM
Well, now I know I have a standard GPR like most of the trucks. I read somewhere that alot of the electronic ones were on cali emission vehicles. Besides, I changed mine today and it works good now. I went to napa they didn't have any more GPR 109's, so I just bought the properly fitting GPR 110. Every repair is a great learning experience.
2002 f350 cold starting problems chaoticghost 1999 - 2003 7.3L Power Stroke Diesel 21 01-11-2015 02:28 PM
1989 Ford F350 7.3l IDI mister_eicher Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 11-10-2014 06:14 PM
Glow plug relay? Controller? 86351wHOsupercab 1999 - 2003 7.3L Power Stroke Diesel 11 10-25-2013 09:45 PM
Bad glow plugs or bad relay? BullRidnRenegade Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 02-16-2012 07:28 AM
Truck wont start glow plug circuit issue (yes another one) the Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 08-06-2011 09:59 PM
Tags
2003, 49l, 73, 99, controller, diesel, e350, f150, ford, glow, located, module, plug, relay, timer, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
