Mirror turn signal plastic? Can it be replaced?
If im seeing the pictures correctly its only the light that is broken? If thats the case theres no need to replace the entire mirror just buy new signals. You can get aftermarket turn signals from companies such as Recon, though recently Recon's customer service has been questionable. Anyway replacing the signals is a PITA. You must angle the mirror in order to get behind the mirror and locate three plastic tabs that hold the outer mirror shell to the complete assembly. These tabs are fragile and I broke a couple of them but just ended up plastic welding them back together. After you take the outer shell of its as simple as taking out the old light and putting it all back together. Definitely cheaper than buying a whole new mirror set just use more patience than I did
Yeah, you can replace the signals with RECON units, but if you want the OEM amber units, you have to buy the cover (not the whole mirror assembly). Ford doesn't sell the covers or signals individually. Atleast that's what my parts guy says. Maybe there are aftermarket OEM style replacements out there.
Thanks. Missed that.
Here is what his site comes up with for turn signals on a 2006.
<table class="tabletext" align="center" border="0" cellpadding="3" cellspacing="0" width="100%"><tbody><tr><td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" valign="top">duty - 1999-07 SUPER DUTY
</td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="center" valign="top" nowrap="nowrap"> 02-07 </td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top">$164.09</td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top"> </td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top"> $88.61 </td> </tr> <tr> <td class="tabletext" colspan="5" style="border-bottom: 4px double rgb(255, 255, 255);"> <table border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td class="tabletext">
Electrical - Chassis electrical - Switches - Turn signal & hazard switch </td> <td class="tabletext" nowrap="nowrap"> </td> <td class="tabletext" align="right" nowrap="nowrap"> </td> </tr> </tbody></table> </td> </tr> <tr> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" valign="top"> W/turn signal Right
</td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="center" valign="top" nowrap="nowrap"> 03-07 </td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top">$101.18</td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top"> </td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top"> $72.85 </td> </tr> <tr> <td class="tabletext" colspan="5" style="border-bottom: 4px double rgb(255, 255, 255);"> <table border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td class="tabletext">
Front door - Outside mirrors - Mirror glass - W/turn signal </td> <td class="tabletext" nowrap="nowrap"> </td> <td class="tabletext" align="right" nowrap="nowrap"> </td> </tr> </tbody></table> </td> </tr> <tr> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" valign="top"> W/turn signal Left
</td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="center" valign="top" nowrap="nowrap"> 03-07 </td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top">$96.82</td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top"> </td> <td class="tabletext" style="border-top: 4px double rgb(255, 255, 255);" align="right" valign="top"> $69.71 </td> </tr> <tr> <td class="tabletext" colspan="5" style="border-bottom: 4px double rgb(255, 255, 255);"> <table border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr> <td class="tabletext">
Front door - Outside mirrors - Mirror glass - W/turn signal </td> <td class="tabletext" nowrap="nowrap"> </td> <td class="tabletext" align="right" nowrap="nowrap"> </td></tr></tbody></table></td></tr></tbody></table>
any idea on which one I need? Is it the bottom one?
I suggest calling Ed and explaining what you need. In my case, the mirrors were part of the tow package. Very easy to replace once you see how it comes apart.
On my 2004, there are three tabs that have to be released. Tilt the mirror to different positions to access each. A flash light helps.. good luck..
