1999 v10 automatic trans shifting problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-28-2011, 06:07 PM
blackwellsgamefowl blackwellsgamefowl is offline
blackwellsgamefowl is starting off with a positive reputation.
i have a 1999 f350 4x4 sd with the v10... truck has around 180k on it and im havin some shifting probs... when the truck shifts into 3rd the rpms drop to 1500 and the truck shakes if i take it out of overdrive it shifts normal. any suggestions on whts wrong..... oh and its an automatic trans....
Old 05-28-2011, 10:47 PM
wizardsr's Avatar
wizardsr wizardsr is offline
wizardsr is gaining momentum as a positive member of FTE.wizardsr is gaining momentum as a positive member of FTE.
Quote:
Original 4r100 trans with 180k? Count your blessings!
Old 05-28-2011, 10:58 PM
mwsmith100 mwsmith100 is offline
mwsmith100 is starting off with a positive reputation.
Why?
Quote:
what is the typical failure mode on those trans? I'm about 45K miles away from 180K
Old 05-29-2011, 09:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I think you have an engine miss.
Old 05-29-2011, 10:13 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
Quote:
I got 230+k out of one, 240+k out of another 4r100, both in trucks that pulled trailers for most of those miles.
Old 05-29-2011, 06:41 PM
thanks for the info i had a guy tell me it was somthing called a torque lockout sensor or something of that nature. but i wasnt sure. any more info on how to fix it would be great. im a fix it myself kinda guy if i can.
Old 05-30-2011, 11:08 AM
I've never heard of anything like a torque lockout sensor. I think it's an engine miss, either a coil or a spark plug.
Old 05-31-2011, 06:21 PM
ok well we will try changing that stuff first. and see what happens.
Old 05-31-2011, 06:36 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Just out of curious when the last time the truck had the spark plugs and boots changed?
Old 05-31-2011, 08:39 PM
Do you just change parts on someone's recommendation? Especially someone that hasn't looked at the truck? Don't you think some diagnostics are in order?
Old 06-01-2011, 12:17 PM
wizardsr's Avatar
Quote:
Nonsense, we all know he just needs that CarMD thingy that plugs into that thingy under the dash that will tell him what parts he needs to replace. LOL
1999 F250 4x4 Transmission Sensor Kidsnmud 1999 to 2016 Super Duty 16 05-22-2016 07:16 PM
2001 F250 trans problems? thunderbolt427 1999 to 2016 Super Duty 4 09-02-2015 08:35 AM
question on an engine swap Klevurrwon 1999 to 2016 Super Duty 3 04-02-2013 10:32 PM
Thinking of buying 99 F350 V10 Auto Kert0307 Modular V10 (6.8l) 5 11-27-2010 10:37 PM
Trans shifting oddly ATXZJ Modular V10 (6.8l) 2 03-18-2008 11:25 AM
Tags
1999, adjustment, buy, diesel, e350, f250, f350, ford, hard, motor, problems, recalls, shift, transmission, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
