engine swap 5.0 to 4.9 ?
Old 03-24-2003, 09:08 PM
slobojw's Avatar
slobojw
slobojw is offline
Post engine swap 5.0 to 4.9 ?
Just looking for info and if anyone has tried this swap and what problems they had.The truck it is going it to is 86 F-150 5.0 EFI 4X4.
Thanks for all info.
Julius
Old 03-25-2003, 04:21 AM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
First of all are you planning on using a carbureted 300 or EFI? Either way you go you will need the 6 cylinder motor mounts, a clutch and flywheel, the correct down pipe to connect the exhaust system, and you may need to change out some of your wiring depending on whether or not you are running carbs or EFI. You might need to change your radiator, will at least need to change your coolant hoses. Other than that the 300 will bolt to the same bellhousing as your 302, The swap should go pretty much trouble free, concidering most of the accessories and wiring off your <a href="http://motorhaven.autoanything.com/">302 </a>should transfer to the 300 with no trouble. Good luck!
xlhr8r
05-12-2015 10:49 PM
Crewcabber
06-28-2014 11:34 AM
GTBksRule
01-29-2013 07:53 PM
blacklab1
02-22-2010 10:17 PM
Blue Cruser
1983 - 2012 Ranger & B-Series
12-22-2008 10:00 AM
Quick Reply: engine swap 5.0 to 4.9 ?
