I have a 97 F-150 ext. cab 4x4. The antenna connection at the radio, and the cable are badly corroded, and need to be replaced. Has anyone done this? Any tips to make replacing it easier?
Is this a common thing. I just got a 97 and the cable is corroded to the point it came apart when I was trying to figure out why the radio didn't work.
I haven't taken apart the attena side yet, is the cable crimped on requiring a whole new attena or is there a connection there also?
The way I used to do them is,
take off the antenna, cut the wire and tape the new wire to that end. Pull the old wire through to the inside with the new wire attached. Un-tape it and plug it in. Mount new antenna.
Phil, that's what I was thinking of doing. There is also what looks to be a panel on the top of the dash, that may be able to pop out, I'm going to look at that also.
I've read about some of y'all replace antenna cable and all that but could someone please tell me where I could find the whole cable that run from the antenna mount and all the way through to back of CD player... I don't wanna have to just solder an adapter on I just wanna replace the whole cable as the factory cable already is and I'm trying not to have to order one cause all the ones I have fount has to come with a new antenna and all and I wanna keep the one I have any suggestion is greatful thanks!!!!
