Pollak Valve
When I spoke with Ford parts man 2 weeks ago he led me to believe the Ford part was for gas and diesel. The $325. that stopped me cold, stopped me cold.
I did find on amazon.com 6c3z9189a Ford Pollak for $275. another site had it for $375. The NAPA part is $105., but not the same configuration. What sort of trouble would I get into if I cut the nylon line , could I slide a piece of rubber line over the nylon and clamp it? All help is appreciated.
The Pollak NAPA valve sure looks like a different line attchment than what I have which is the same as the one on amazon.com 6c3z9189a, I would give a link but I am not that computer literate. The ends on the NAPA valve are not elongated like 6c3z9189a they are more like a hose barb. Yes my fittings push on and have the hair clip.
Sudford, I want to thank you for your help on this matter.
I looked at both of the threads, did a silverstateford and partsguyed and they wanted $226 or $231. both better than my local ford dealer. However being on SS Disability I count my ($$) 10 or 15 times before I spend them. The NAPA $105 + $10 for the pigtail is affordable. Cutting the lines and adding rubber line is not a big deal, or is that famous last words. Would a 3" overlap onto the nylon line be good or do I need more? I am also considering moving the valve about a foot closer to the engine to make it more accessable. What do ya'll think? Thanks
FORDF250HDXLT
05-11-2016 07:54 AM
6eightF250
10-24-2011 09:03 AM
Patman-TX
34
12-09-2010 01:45 PM
mark89
04-11-2009 02:19 PM
