Rev-X Fuel and Oil Additives - Ford Truck Enthusiasts Forums
Old 05-28-2011, 01:28 AM
Wildfire532FB's Avatar
Wildfire532FB Wildfire532FB is offline
Wildfire532FB is starting off with a positive reputation.
Anyone know if this stuff is good?
Old 10-07-2011, 08:11 PM
Javo's Avatar
Javo Javo is offline
Javo is gaining momentum as a positive member of FTE.
Sorry for the late response but I was looking around and came across your thread. I have been using the Rev-X for about a month and a half and I definitely notice a big difference when I first start my truck in the morning. It's much smoother and doesn't have that rough idle except for just a few seconds. However, the weather hasn't gotten cold yet so I guess the real test will be this winter. It's expensive, about $70 per treatment. For what its worth at this point I will add it again at my next oil change. There are some videos on YouTube with people doing before and after cold starts, check em out.
Good Luck.
Old 11-23-2011, 07:28 AM
dano6257 dano6257 is offline
dano6257 is starting off with a positive reputation.
I was experiencing very poor performance before the engine reached normal operating temperature (stumbling, missing, jerking, etc); from what I have read, I seem to have had the same symptoms as what is referred to as "stiction" in regards to the injectors. I have 170K miles on the truck, I put in two bottles of the Rev X after an oil change and now the truck runs great. I was very skeptical at first, regarding how I could fix this problem by simply adding something to the oil, but I have been very pleased with the results. I don't claim to be a chemical engineer or even fully understand what this stuff does, but I have no regrets paying the $70 for it.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
64, 73, additave, additive, alternative, colorado, f150, f350, ford, fordtrucks, forum, forums, oil, rev, revx, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
