5r55w tranny drain plug - Ford Truck Enthusiasts Forums
Old 05-27-2011, 09:57 PM
old farmer old farmer is offline
old farmer is starting off with a positive reputation.
I have been thinking of doing an oil change on my 2005 Aviator tranny.
Can the large plug with the standpipe in it be removed or is it welded or pressed into place?
What is the differences between the 5r55w and the N and S versions looking at it from the outside?
I would also like to change the rear diffy oil because of the howling and other issues I read about. My brother had to have his diffy in his 2002 Explorer rebuilt, and it still whines a bit. I'm sure the Aviator has the same diffy and tranny, and I want to prevent trouble now while it's working good.
I also want to flush and change the coolant. I always used to install a flushing tee in the heater hose going from the engine to the heater, pull the upper rad hose off at the rad and flush backward through the engine to the rad and out the inlet. Will that work with this one?
Thanks in advance for any advice.
Old 05-28-2011, 09:24 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
on the tranny, the big plug drains the oil. THere is a 2 inch tall standtube on that plug. the small plug that looks like 1/8 inch pipe plug is where you refill with a weed sprayer type pump.. the oil goes in untill it fills the pan to the top of the 2 inch stand tube in teh big plug.. pull the big plug and drain and you will get the idea......... rear end can be many things. my 2002 has a slight whine. it is loudest at 60 MPH. It goes away if you take your foot off the gas pedal.. that means its not a bearing, its gear whine. You can change the oil viscosity , etc and that can help.. i use 75w 140 full synthetic with the friction modifier, even tho i dont have a Limit slip rear endd.. about 2/3 of the noise goes away.. been there for 100k miles....... your idea with the radiator flush is good.
Old 05-29-2011, 06:08 AM
OK thanks Steve.
Socal New Old Guy whalepirot New Member Introductions 5 05-04-2015 09:24 PM
new 65" f1oo florida65 1961 - 1966 F-100 & Larger F-Series Trucks 8 07-13-2014 02:55 PM
newbe with 9" differential retro48/52 Clutch, Transmission, Differential, Axle & Transfer Case 11 03-28-2014 09:51 PM
Overheating after heat core flush Danny Stroup 1973 - 1979 F-100 & Larger F-Series Trucks 20 01-11-2010 09:05 PM
How does AWD work? old farmer Explorer, Sport Trac, Mountaineer & Aviator 2 04-10-2009 11:06 PM
Tags
04, 5r55e, 5r55w, aviator, diesel, drain, explorer, foot, ford, gas, howels, illinois, pedal, plug, refill, sale, size, tool, transmission, ya
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
