89 f250 fuel pump problems - Ford Truck Enthusiasts Forums
Old 05-27-2011, 09:31 PM
deanna197 deanna197 is offline
deanna197 is starting off with a positive reputation.
i have an 89 f250. having issues with the fuel pump system. my truck died the other day, the fuel pump wasn't kicking on. i tried replacing the relay, nothing. pulled the pump and tested it, it works just fine. i tried running a new wire from the relay hot wire to the pump and that got the truck running, but the fuel pump won't kick off ever. help
Old 05-28-2011, 12:58 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to correct forum.
Old 05-28-2011, 09:04 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
Check the fuel pump cut-off(accident(inertia) switch) that's under the driver's side dash area on the firewall. Reset it by pressing down the red button. If that still doesn't help, use a test light and see if you are getting power to that switch. If you have power to it but none out, its time to replace it. My failed and I just capped the wires together while on the side of the road.
Old 05-28-2011, 09:21 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
If pushing the button down on the fuel pump cut-off(accident(inertia) switch) or jumping it does not help then:
Does the fuel pump relay click when you turn on the key and click again (drop out) one second later?
If not ground pin #6 of the Self-Test plug on the drivers fender and turn on the key and see if the selected fuel pump runs then.
87 F250 460 fuel tank selector relay location? jumbofordman 1987 - 1996 F150 & Larger F-Series Trucks 2 02-02-2015 06:15 PM
Fuel pump issues landtortise89 1987 - 1996 F150 & Larger F-Series Trucks 4 09-12-2014 09:23 AM
Fuel Pumps Keep Running daveandmoe 1987 - 1996 F150 & Larger F-Series Trucks 10 01-29-2014 06:58 AM
No Power to fuel pumps lopitt85 1987 - 1996 F150 & Larger F-Series Trucks 10 09-01-2009 09:54 PM
89 f150 4.9l fuel delivery problem protow2000 1987 - 1996 F150 & Larger F-Series Trucks 10 08-12-2006 12:12 PM
Tags
1987, 1989, 1996, 89, f250, failure, filter, ford, fuel, hot, location, problem, problems, pump, relay
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
