Guage cluster dieing!!!
I noticed this morning on my way to work that I was out of gas but yesterday I had plenty. I put $25 in my tank and went on my way realizing that only got me 1/4 tank when usually that more like 1/3 tank. Then I realized the temp guage was hardly moving and the oil press was way low!! I'm thinking it's a ground issue.. Any other ideas or thoughts on where to start?? Tomarow I'll pull the cluster and clean all terminals and contacts. Also.. What wire could I tap into to add another ground??
1967/72 F100/350: There are three different ICVR's used on these trucks, because...1970/72's have printed circuit boards. 1967/69's do not.
The printed circuit boards used in 1970, are 1970 only, as is the ICVR.
1971/72's use the same boards / Note: 1970/72: The boards are specific to: With oil/amp gauges / With oil/amp warning (idiot) lights.
1967/69 F100/350: C6DZ-10804-A .. ICVR = Instrument Cluster Voltage Regulator (Motorcraft GR-510) / Obsolete
1970 F100/350: C9AZ-10804-A .. ICVR (Motorcraft GR-512) / Obsolete
1970/72 F100/350: D1AZ-10804-A .. ICVR (Motorcraft GR-513) / Available from Ford.
1967/69: The ICVR bolts to the back of the instrument cluster.
1970/72: The ICVR snaps onto the printed circuit. Be very careful when removing the ICVR, if you tear the printed circuit, you'll be huntin' for another.
Available from autoparts stores, but make sure to take the original with you, so you can match it up.
Besides these 3 ICVR's, there are 5 more used on other FoMoCo vehicles.
JayzDaddy
08-27-2014 02:49 PM
The other Joe
06-09-2014 11:38 AM
arockyway2go
06-02-2014 12:01 AM
