96 F150 Y-Pipe w/cats
Eastern makes a OEM fit direct replacement for your 1996. It is not CARB compliant, 49 state only. Model number is 30276. No one else makes one like that for a '96 that I have found. You could use one designed for a 1995, but you will need to add the bungs for the oxygen sensors in the correct place, 3 total.
Checking around the web also shows mixed results for that y-pipe/converter. It may not have all the necessary oxygen sensor ports either.
Ford switched to OBD-II on the light trucks in 1996. This changed how the computer sensed and controlled the engine. Odd I can find y-pipe/converters for the 4.9 and 5.0L trucks but not the 5.8L 1996 trucks.
Further investigation confirmed my suspicion. It has only one O2 port. Looks like most anything you get off the shelf will need to be modified.
schnide
Exhaust Systems
02-28-2014 09:55 AM
Dayzed50
1978 - 1996 Big Bronco
11-02-2010 10:04 AM
