1991 f250 460 fuel injectors not triggering - Ford Truck Enthusiasts Forums
Old 05-27-2011, 01:29 PM
Tazz54 Tazz54 is offline
Tazz54 is starting off with a positive reputation.
Ive got a 91 f250 460 and there is no current to the fuel injectors i am lost and dont know where to start lloking for the culprit thansk for any and all info to this problem Tazz
Old 05-27-2011, 03:48 PM
BuickBrian's Avatar
BuickBrian BuickBrian is offline
BuickBrian is starting off with a positive reputation.
1st thing to check is the small ground wire with a round, black connector on it coming out of the negative battery cable terminal. If that is not connected or has a poor connection, you will not have a ground to the computer and the injectors will not fire. This wire goes straight to the computer ground terminal. The check engine light will not come on when you turn the key on if the computer is not getting a ground or not getting power.
If that is good, you can dig deeper:
I power wire feeds all 8 injectors and they are controlled by the computer turning the ground to them on and off. It fires 4 injectors at a time, so there are 2 ground wires and one hot wire going to the main connector on the computer. Start by getting a Ford wiring diagram for the truck and checking continuity between the appropriate 3 pins in the computer connector and the injectors.
Old 05-27-2011, 04:28 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
The power to the injectors comes from the EEC Power Relay over a Red wire.
The relay is turned on and off by the Ignition switch.
This same Red wire also powers the Computer, other solenoids and the fuel pump relay coil.
Old 05-27-2011, 06:43 PM
Thank you for the info ill check this wire and where can i get a wiring diagraphm can i possibly get 1 here?
Old 05-27-2011, 06:47 PM
Hi Bill thanks for this info ill check this out hope i find the source Where would i find this EEC Power Relay and BuickBrain meentioned getting a wiring diagraphm to check on three wires going to the computer Where could get one of these? or possibly on here? Thanks Tazz from Collins Mo
Old 05-27-2011, 07:12 PM
subford's Avatar
Here is two diagrams of the 1990, I think the 1991 is the same:
Old 05-27-2011, 07:16 PM
subford's Avatar
The ground for the computer (G102) and the EEC power relay (G201) are not the same place.
Fuel injector question. Brian Ski 44 1987 - 1996 F150 & Larger F-Series Trucks 6 06-26-2016 06:45 PM
2wd to 4wd Tazz69 1997 - 2003 F150 2 04-10-2016 09:31 AM
Leaky injector 460 zackcj7 1987 - 1996 F150 & Larger F-Series Trucks 3 05-23-2015 10:41 AM
Help! Not getting power to injectors on my 460 Mkoch1991 1987 - 1996 F150 & Larger F-Series Trucks 5 07-31-2014 10:12 AM
92 f250 460 injector rebuild wr310rdr 1987 - 1996 F150 & Larger F-Series Trucks 4 07-26-2014 11:58 AM
Tags
1987, 1991, 460, 50, 91, f150, f250, ford, fuel, injecters, injection, injectors, negtive, noiding, power, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
